Finish Problem
Finish Problem
Finish Problem
Cyril Griesbach
>I guess I've done something wrong so I'm looking for some answers. I turned a shaving brush handle from Padauk, put some sanding sealer on prior to the 280 and 400 grit sanding. Then applied some Formby's tung oil finish and let it sit about 36 hours. Next day I put on some Min Wax wipe on poly but after three days the poly is still tacky. Clearly somethings incompatible here but I don't know what. Tung oil and poly are reasonably fresh cans. What happened?
Re: Finish Problem
Dominic in Bucks County PA
Re: Finish Problem
>I've had similar issues with paduak. It is a naturally oily wood. About the only thing I've found that will help is to wipe the wood down with mineral spirits before applying any finish and allow it to dry. From what I understand (I haven't tried it yet), shellacing before applying a finish helps as well.
Re: Finish Problem
Sealer's the answer
>Padauk and other Pterocarpus and Dalbergia species have chemicals in them that inhibit varnish curing. If your sanding sealer dried hard, the problem must have been that you sanded through it to bare wood. It's best to just lightly knock off any nibs (I use 320-grit)and be careful not to sand through. The heavy dose of stearates in sanding sealer that make it easy to sand also make it brittle and friable. Personally, I would have used shellac as my sealer coat.
Re: Finish Problem
Oh, and as Dominic said...
>... wiping the surface with naphtha or mineral spirits before applying the varnish is reputed to work -- I believe Bob Flexner advocates this approach -- although I haven't had much luck with it. In theory, it removes the surface oil and allows the varnish to set up before the oil migrates back to the surface. If it works reliably, I'd like to hear more about it. What solvent, what wood, what varnish, etc.?
Re: Finish Problem
Re: Oh, and as Dominic said...
Cyril Griesbach
>I think there is little doubt that I sanded through the sanding sealer. I turned another prototype and just put on the poly and after two hours it seems to be curing. That is, so far.
Re: Finish Problem
Re: Finish Problem
Texian
>This is probably a dumb question, but why would you want to use tung oil under poly?
Re: Finish Problem
Re: Finish Problem
Cyril Griesbach
>Not a dumb question, Texian, just a dumb idea to do so.
Re: Finish Problem
Re: Tung Oil?
Ron McKinley
>From what I've heard there is no tung oil in Formby's Tung Oil. It's all varnish.......Ron
Re: Finish Problem
Re: Finish Problem
Texian
>That's ok. Everybody is entitled to a few of those.
Re: Finish Problem
Re: Tung Oil?
jim miles - Charlote NC
>Varnish is primarily tung oil
