Re: newbie question
keith zimmerman, Normal, IL
>Tony, it sounds like you just want to turn off center and not multi-axis. There are several off center or eccentric chucks available out there in the market place. If you do a search on off center turning, you will find several. They are available from several manufacturers as well as plans for making your own.
There are also several other ways to mount wood off center, such as double stick tape or screws to hold your working piece to another piece of wood that is attached to a faceplace. You could also use a rectangular glue block on your piece and mount it to a chuck with only the opposing jaws attached. By adjusting the centerpoint of the rectangular block, you can turn off center on the face of your work piece.
Good luck with journey into off center turning.
keith
