I have read somewhere that it may be possible to use a motor out of a treadmill to power a lathe but don't remember where I read it is this really possible? I see treadmills from time to time on freecycle. There is one there now.
>Treadmills generally have 2-3 hp variable speed DC motors (typically pretty decent brushless setups). They require a brushless motor controller. Obviously, there is one built into the treadmill's electronics already, or you can build/buy a new one.
If you took apart a treadmill and salvaged the wiring harnesses and controller board etc, it would probably be a pretty easy retrofit, and definitely cheap.
Several years ago, Mark Kauder posted a step-by-step "how-to" article on using a DC variable speed motor from a treadmill on a Jet Mini-Lathe. It is necessary to use the circuit board controller (and associated potentiometer for speed control) together with the motor taken from a treadmill. For a while, you could buy a new 'surplus' treadmill motor and controller board from Vega to do a conversion of lathe motors. Mark's instructions are easy to follow and work OK. Make sure you follow proper heat sinking of the necessary parts on the circuit board.
One of the modifications, as I recall, is to cut-off one of the transistors on the circuit board to remove the 'speed ramp' function which provides for a slow start to the treadmill. Of course, you can also add a "motor reverse" to the system so you can run the lathe "backwards", which would be a good additional feature to consider. The link I provided below is an explanation by Mark Kauder of how to use a treadmill motor, however the illustrations that apparently accompanied the text are no longer supported on the server.
>I bought a used treadmill at my local thrift store. It was priced at $30. When I asked the clerk to plug it in & see if it would run - it would not so he offered it to me at $15. The clerk did not know it had a safety overide feature. I figured I would take a chance on it for $15. . Turned out it was an Emerson 3/4 Hp 1725 motor hardly used. ( treadmill ! ) It had a mechanical speed controller that I was able to salvage. Used it on a small purpose built lathe.
