Veritas - Innovation in Tools
On to some motor help, please *LINK*
Scott Burr in Ben Lomond CA
>So as I still work on my pulley speed spread sheet calculating motor speeds, I had a chance to pull apart and clean the motor that came with the lathe. It's a 1/3 HP, 6.3Amp, 1725 RPM motor (I should have put on my glasses, in a blur I thought I saw 1750).
All the better I think a slower motor the better up to a point.
So I'd like to put a switch in the motor for forward rotation and reverse.
Now I'm a rookie when it comes to wiring like this. I gave it my best shot below.
Will this work?
What kind of switch to use?
As usual I'm in total quandary.
The link is to a power switch I'm thinking of using.
Thank You!
Scott
Power switch
Re: On to some motor help, please *LINK*
Doc Green
>Scott, your diagram for the switch is correct.
As you probably realize, since you have the diagram, you need a double-pole, double-throw switch to do the reversing. Such a switch has 6 terminals unless part of the wiring is included inside the switch. Here are a couple of options:
1. Use a DPDT toggle switch with 6 terminals and make the cross connections yourself.
2. Use a four-way switch that is used for residential wiring when it is desired to switch a light On or Off from More than two locations. These switches have only 4 terminals but the cross connections are built inside the switch.
The Power Switch shown in the link you provided will work fine, but it is more than what is required unless you want the push-button capability. A simple toggle switch will work.
Good Luck! ~Doc
Roger
>As Doc said, the 4 way switch as used in residential wiring will work perfectly. I put one on my old Craftsman monotube lathe with 1/2 hp. motor and it worked like a charm. Good luck.
Roger
Thanks Doc! One more question...
>Do you think I could use a standard residential light switch for a power switch?
That would save me some $$.
Thank you!
Scott
Re: Thanks Doc! One more question...
Doc Green
>Yes, an ordinary light switch will work just fine. Further, you can use a piece of (dry) wood to make a mount for the switch and customize the installation. Just be sure the contacts are covered. Dry wood is an excellent insulator. ~Doc
Ace Foster
>Tom Parramore or Tom Steele down at Scarborough's should be able to fix you right up. Tell 'em Ace sent you.
One more thing.....
>I made a home made reversing switch for my old Craftsman monotube lathe also. It was crude to say the least, but I used it for years. If you want to know how I did it, ask and I'll try to describe it.
And, at one point I tried to use a residential wall mounted mercury switch for the on off. Except that I tried to use it laying down on a counter. Did not work at all. Was told it had to be vertical. Just make sure your switch will operate in the position you chose.
OK, I think I have it...
>Thank you for all your great advise. As one can see I'm a wiring rookie as well. Please review my schematic to see if I have it right.
Again, Thank you all so much!
Scott
OK Ace, Whitch one?
>Scarborough? I was just in the Ben Lomond one getting a 4-way. Boy that sounds kinky...8^)
Are you in my neck of the woods?
Danger Will Robinson! Danger!
Curly Smith
>If I followed the discussion correctly and the white and black wires on the right of the diagram are your power in then STOP. You should connect the switch across the black (power side) only and connect the white (neutral) to the motor. As drawn, you'll have a short and blow your circuit breaker as soon as you thrown the switch.
Again, connect the black wire in to the switch and then a jumper to the motor. Connect the white straight to the motor and connect the ground to the ground if there is one.
Danger indeed Curly!
>Can you tell I haven't done this in decades...
Let's try this again, 'nothin up my sleeves and presto!
I hope...
Re: Danger indeed Curly!
Curly Smith
>That should be right. It's the same as your first diagram but with a switch across the black line in.
Stop! 4-way switch wrong
Doc Green
>Scott: (1) The 4-way switch is wired wrong, and (2) I believe you have the switch terminals rotated 90 degrees from what it should be.
Assuming I'm correct about (2) above, here's how the wiring should go:
Run a wire from terminal 2 of the motor to one of the copper screws.
Run a wire from terminal 4 of the motor to the other copper screw.
Connect the blue wire to one of the black screws.
Connect the yellow wire to the other black screw.
Note: Swapping the blue and yellow wires on the black screws will change the direction of the motor, for a given position of the switch actuator.
Method to check my assumption regarding (2) above:
Needed: Two short pieces of wire (can be small diameter) and a flashlight battery. (Battery can be a C or D cell, or an AA.)
First, make some sparks ... strip the insulation from the ends of one of the wires. Hold one end of the wire onto one end of the battery. Then, lightly scrape the other end of the wire across the terminal on the other end of the battery. You should see small sparks that indicate that a current is flowing through the wire. Do this in an area with dim light so you can see the sparks.
Once you see the sparks, go on to the next step.
Next step: Strip the insulation from the ends of the other wire.
Connect one of the wires to one of the copper screws.
Connect the other wire to the other copper screw.
Now, repeat the test with the battery...hold the bare end of one wire against one end of the battery. Scrape the bare end of the other wire across the terminal on the other end of the battery. If you Do Not see sparks, then my assumption may be correct, but take it one step further.
Flip the switch actuator to the other position and repeat the test. If you still do not see sparks, then my assumption is correct, and the switch should be wired as I described above.
If you Do see sparks, then my assumption is wrong. Report back with this result, and I'll give you another way to wire the switch.
More Fun: Remove one of the wires from a copper screw and connect it to one of the black screws. Now, you Should See Sparks when the switch actuator is in one position, but not the other. If it works out this way, it simply confirms the previous test.
Safety note: Don't hold the wire onto the battery terminal. Just scrape the wire across it. Holding the wire onto the terminal will tend to run the battery down.
Let us know how this works out. ~Doc
Denis Putland
Denis Putland
>Hi
I see that there some if's and maybe's in your attempts to reverse your motor.
So I am including a link to the proper and safe way to reverse your motor.
Denis
http://www.grainger.com/1/1/83897-da...aintained.html
Be very careful,,,,
>I have read your posts and the responses and managed to get confused. I have done this a few time over the years. Let me try to explain what I remember. You are doing two different things with two switched and they should have no shared wires.
First, the ON/Off switch. Connect the black wire from the cord/line to one screw on a ordinary on/off single pole switch. The switch should have two similar screws. On may be labeled "line" and the other "load". If so, connect the incoming cord/line to the line side screw. Connect the black wire "load/feed" going to the motor to the other screw. Newer residential switches have a ground screw on them, usually green. Connect the ground wire to that. The white wire should be connected to the motor and should not be switched. Also connect the ground to the motor.
The second switch control the direction of the motor and is not connected to either the black or white wires mentioned above. You could/should ground this switch also as mentioned above. The wires for this switch are in the box mounted on the motor. They are usually connected to terminals with spade connectors. As they are connected when you got the motor, the motor ran in one direction (forward?). Lets say they are A to A and B to B. IF you pull the connectors off the spades and switch them so the are A to B and B to A, the motor will run in the other direction (backwards?). So to make the switch do this, you extend wires out of the motor far enough to reach your switch and connect one to each screw on one side of the switch. Connect similar set of wires to the screws on the opposite side switch and back to the connectors on the motor. The 4 way switch flips the wires internally, changing AA and BB to AB and BA just by flipping the switch. You might want to lable the cover plate F And R to save fumbling later.
This would be easier if you use spade connectors similar to the ones already there. Get the connectors and a crimping tool if you haven't got them already. You will need both male and female types.
IT"S ALIVE!!! and one last question...
>A big shout out to Doc and Curly for pointing out my mistakes and great general guidance. As well as everyone who replied to my post. I learned and retrieved a great bit knowledge form my college daze and you all.
Doc got it right his 4-way switch wiring did the trick. It passed the battery test and a sloppy prototype wiring job to test it all out.
Thank you all for all your wonderful help!
Now one last stupid question:
When I'm standing in front of my lathe which way should it spin for turning?
Re: IT"S ALIVE!!! and one last question...
wilbur
>Good to see you're up and running.
The lathe should be rotating so that the top of the workpiece is rotating towards you, then down, "pushing" your gouge down onto the tool rest.
Doc Green
>Congratulations, Scott! Wasn't so hard after all, was it?
You provided excellent information from your end. The photo of the terminal diagram made it all possible.
Lathe direction clarification: You want to take wood off the piece or put it back on?
~Doc :)
Re: OK Ace, Whitch one?
Ace Foster
>It does sound kinky.
I worked at that Scarborough for half a dozen years before moving to Wahngton in '05. Possibly the most enjoyable jod overall that I ever had. Great folks!
Ace
Why put it back on! Of course...
>It's kinda like a board stretcher right? Fix all my mistakes right? 8^)
Let's start with taking it off. Until her dad get home anyway...
Still good poeple there and the only ones,
>I'll let touch my chainsaw.
Ace at Ace interesting Ace...
