Delta 46-460 lathe
Delta 46-460 lathe
Delta 46-460 lathe
BQ in VT
>Has anybody used one? My 9 year old Jet is one the way out.
Re: Delta 46-460 lathe
>Yes I used this lathe at the Toronto Wood Show last year and was very impressed. You will not be disappointed with that purchase.
Bernie Weishapl
>I have the Rikon and it is a really nice lathe for the money. I have used the Delta 46-460 4 times now and love it. I wish it had been out when I got my Jet 1220 as I probably would have ended up with the Delta. It is smooth, quiet and does have more power than the Jet.
Bill Blasic
Bill Blasic
>The Delta is the Midi that every company should make.
Bill
keith zimmerman, Normal IL
>I have had mine since May and really like it. As far as I am concerned, it is as close to perfect as it can be. I really like the VS ranges, the reversing, the swing, the indexing, and the machine is built very stoutly.
I have turned on both the Rikon and the Jet 1220 and, in my opinion, the Delta is a superior machine to both of them.
You will not be sorry if you buy one. Delta did this one right.
keithz
Paul Kramer
Paul Kramer
>B,
I, too have the new Delta. I like it a lot. I have only owned the previous Delta Midi. What a huge gulf between the two. The new machine is so much better in every way. The continuous variable speed and reversibility are two superb additions. The belt changing (speed changing) is so solid and sure and is much better. The locks on the banjo and the tail stock are also sure and solid -- no more sliding tail stock as I turn the crank. Being able to turn the speed down to 250 rpm's gives me tremendous feeling of safety when starting out a piece (not as much as being able to turn it down to 10 rpm's on the mustard monster but I don't have one of those. Just got to use one once). The added power is also a plus though I have only had a chance to put that to use once so far. I'm very happy with the purchase.
The only minus so far is that various accessories are not available as yet. I got mine from http://www.Dynamitetoolco.com/ for $599.99 if I remember correctly but no tax and free shipping.
No connection with Dynamite just a happy customer.
Paul
