REAL MILK PAINT
glaser screw chucks and stucks bowls
BQ in VT
>does anybody know how to remove a stuck blank for a glaser screw chuck short of cutting it off? In the past, I have inserted the 2 tommy bars and by unscrewing the flange partway, loosen up the blank enough to get it off. In this case, I have bent the hell out of the bars and no luck. Any ideas, or do I get the saw out?
Re: glaser screw chucks and stucks bowls
Re: glaser screw chucks and stucks bowls------WebK
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>If I understand your problem, it might be solved by cutting a tenon on the tailstock end of the bowl blank, attaching another chuck to that end and using leverage at that end. I've had to do that once or twice.
------WebKitFormBoundarynU1ZTB7+vw2DOLv+
Doug Turner
>Try a strap wrench ( you can jury rig one from an old leather belt).
John Leonard
>I agree with Doug. I bought two sizes to be sure to have one that fits and they work great. I haven't had a problem since I started using them. I hope that statement isn't some of them "famous last words".
Wally Dickerman in Arizona
>I've had the same problem. I solved it by applying some masking tape to protect the chuck and using a pipe wrench. Lots of leverage. Large slip-joint pliers also work.
Wally
One thing I do
Dave Peebles Lyons, Ohio!
>This won't help this time, but I have had trouble in the past removing blanks from the Glaser screw chuck. These days I coat the screw with some paraffin canning wax. It still grips the wood like a bulldog, but enables you to remove it easily.
Dave
