Caballos Ascendentes
Molly Winton
>First a huge gloat. I met one of my BIG goals this year and was invited to SOFA Chicago. I'm just tickled. This piece will be one on display. It's in my Caballos Ascendentes (Ascending Horses) series, made from California buckeye burl, and is approximately 8 1/2"x7". It was difficult covering up much of the wood with black, but it does make the horses jump off the piece. There are many inclusions in this wood, and gave me a bit of pause wondering whether it would look okay once blackened, but I am quite pleased with it.
Re: Caballos Ascendentes
Ed Heuslein
>Howdy Molly: Again, perfect form. And your traditional pyrography work is second to none. I really like this one. Congratulations of your first (betcha not last) SOFA invitation. I really do look forward to your posts.
Ken Kimura
>Whoa! That's exquisite. You deserve the honors. How did you blacken the piece?
Awsome and well deserved.
Thanks Ed and Ken
Molly Winton
>I blackened it with black gesso (acrylic medium, similar to a primer), then use 3 or 4 coats of spray Krylon Matte Finish.
Wow
Barbara Gill, Remlik VA
Dick Hines
Re: Thanks Ed and Ken
Dick Hines
>Molly this is one great piece. The finish looks like pottery instaed of wood.
How come the burning pens I made don't do work like this?
bowlman
>Again, well deserved! How do you get the gesso so smooth? Sand it? Apply diluted? Curious minds need to know ...
>Congratulations on getting into SOFA! That is one of my goals as well. I love the piece. Hopefully I will get a chance to see it in person at SOFA!
Tom
keith zimmerman, Normal IL
>Congratulations Molly. It is truly an honor to be selected to participate in SOFA. This is a wonderful piece and I like the voids from the burl. It seems to lend an air of mystery to the piece because makes me want to look at each void to see if I can see inside the piece.
I also love that satiny black you achieve. Are you still using leather dye for your blacks? Do you burnish or buff to get this lovely satin finish? My leather dye work is always flat until I wax it.
keithz
Molly Winton
>I don't do anything to change the consistency of the gesso, nor do I sand it. When applying, I pay particular attention to eliminating brush strokes. Gesso does sand nicely though, so if you get brush strokes, using a very fine grit paper will eliminate them.
Molly Winton
>Keith, this isn't leather dye. I can't use the dye on pieces where I have natural wood visible, because of bleed. This is black gesso. It dries completely flat, but then I spray Krylon Matte Finish over it, which gives the satin look. I've found the Krylon to be the best. When I've used other 'matte' spray lacquers, they've still been too glossy. Krylon gives me just the look I want.
keith zimmerman, Normal, IL
>Thanks for the explanation Molly. I already use black gesso and Krylon matte spray. I'll have to try this and see what I can do with it. I hadn't thought of the bleeding aspect of leather dye.
keithz
Steven Antonucci
Great shape and a steady hand...
steve antonucci
Keith Tompkins
Keith Tompkins
>Way to go Molly!
Jorge Castaneda~Downeast Maine
>Congratulaciones Molly!
Muy bonita pieza, dinamica.
Gracias por compartir
Jorge
Beautiful... Great job Molly!
Doug Thompson near Cleveland
ditto, molly
bob davis
