changing insert on Nova chuck
Ken Kimura
>I'll be getting a new insert for the nova scroll chuck. The existing insert is secured with a setscrew and fiber insert. Can someone walk me through changing inserts? eg. how do you get the fiber insert out, which direction to back out insert, how do you get enough purchase to back it out etc? Thanks for any help.
Re: changing insert on Nova chuck
Jerry Hall
>There might be two set screws so check. Maybe fiber insert is glued to set screw? Or use wire to push it out after insert is removed.
Re "purchase" two ways I have used successfully:
1. Use chuck to clamp big scraper or similar, then wrench for insert
2. Open up jaws and clamp gently in wooden bench vise jaws and use wrench for insert.
Hope this helps
GalenV in Iowa
>Sorry no experience with Nova chuck insert, but on my metal lathe I had to change the insert. I would never put two jaws in a vise and let them resist load put on them. Good chance of chipping the scroll. I held the the insert hex in the vise and turned the chuck body with an oil filter wrench. Had to slip an extension over the handle to get enough torque to break it loose.
Just a thought.
Keith Tompkins
Keith Tompkins
>HI Ken, The fiber washer should go UNDER the set screw; it helps prevent damage to the threads on the insert. Remove the set screw, and then use the allen key to push the washer out, preferably on a flat surface so you won't lose it. Thread in the new insert, install the washer, then install the set screw and tighten.
Frederick Nelson
>I recently had to change my insert as well. I first removed the single setscrew from the chuck body - the fiber disk was stuck inside the hole and short of working it out with a dental pick (with no guarantee I'd get all of it) I decided to simply leave it there. Next, I clamped the hex-head of the existing adaptor in my bench vise and used a pair of tommy-bars, one in each of the holes in the chuck body, and un-screwed it in a counter-clockwise direction. It took quite a bit of torque and released with quite a snap, but continued to unscrew with some resistance until it cleared the set-screw hole.
Before inserting the new adaptor, I took the time to clean the threads thoroughly, then applied a light oil to the threads before screwing in the adaptor, and finally replacing the setscrew. A careful spin-up on the new lathe showed it still running as true as before, and I was back in business.
Removing the fiber disk is probably un-necessary, but you might want to push it back from the threads to make it easier to insert the new adaptor. I did not do this, but it did not seem to matter.
I should have something to show off from the new lathe in a few days.
Fred Nelson
Overcast and grey in Eastern Missouri
Ken Kimura
>Thanks Fred, I followed your procedure except I used the body handle that comes with the chuck. It backed out just as you described. The fiber washer looks like part of the threading. I see it keeps the set screw from destroying the insert threads. Still the threads were starting to deform. Since they don't include a new fiber washer, I'll improvise and shove some kind of wadding between what's left of the existing fiber washer and the setscrew. Thanks all for your response
Jim Sebring
>Instead of using a deformed fiber disc, you might try using a .177 air gun pellet or #4 buckshot pellet under the set screw. Both are made of nice soft lead that will help protect the insert threads
