>I am going to buy a new Stihl 250C with the easy start feature. The local dealer was not recommending it. So I need some feedback from some of the users here ( get it or avoid it). Appreciate your valued input.
>Dealer said not needed, only needed on larger saws. I'm "on the fence", as I want a Stihl. Hopefully, someone can explain why to both of us.... John K.
>I have an older 028. Before the easy start feature. The saw is 22 years old and it never fails to start readily. Choke, pull twice, turn off choke, pull once more and I'm in business. If you have limited ability to yank the starter it may be helpful, but then you probably shouldn't be using a chain saw anyway. My 2 cents.
>Does local dealer say WHY not recommending it? A skeptic might think maybe less profit on that model, or they never break down so no potential repair business. Just wondering.
>I retired my 25 yo 028 about 6 months ago. I was looking at the 250 easy start and two dealers in the area did not recommend it. I also spoke with a landscaper who returned one.
I ended up with a 290 and am very happy with it. Starts very easily and has plenty of power. Based on dealer comments, the 290 is a heavier duty saw and a better value because of the large production numbers. Cut through 30" oak without a problem
>I have an 025 with easy start, and I have a lot of experience with chain saws in general. The easy start feature was a little hard to get used to at first. It doesn't really want to be yanked on! Once you get used to it, it's a great feature. Not neccessary, for sure, but might be the future for 2 cycle engines.
>Another response from central Iowa (I live about 1.5 miles from Karl).....
I have a Stihl 260 Pro, and the owner of our local franchise recommended the easy start. It might take about three pulls to get the saw going at first, but subsequent starts are REALLY easy - maybe 'half a pull'.
The real way to test this is to try starting one with the easy start and one without. Don't know if that would be practical or even possible....
>I bought a 250 a couple of years ago and wish I had easy start. It's a great saw, but always takes a min. of 4 yanks to get going when cold. Even though Stihl says there is nothing wrong with it. It's got more compression than I though it would, and is not the easiest to pull. (Although I never did get the hang of drop start technique). Plus, I also have a sore shoulder.
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
Guest
Re: Easy Start on Stihl 250?
>If you have health problems (bad shoulder) or are over 70 years of age, the Easy Start might be a good idea. Otherwise, it is not really necessary. However, I would never buy a 660 without an Easy Stop option (as a matter of fact, I thing they just put the Easy Start in the bigger saws -- no option -- and for good reason).
>My 250,(no easy start), is 2 years old and doing the same as John, I have no problem. My 24" Husqvanna is a differant story. Really need the easy start on that one.
>I've often wondered why Stihl or some other chainsaw mfgrs. don't come out with a feature like a small hex lug that one could spin with a crodless drill to make the beast start. Beats yanking a starter cord, and for those of us with wide feet that don't fit in the handle opening, a much safer way to fire it up. Just a thought ...........
>Is easy start the same as a compression release. I am not familiar with the term easy start. I have a 390 with a compression release and it would be very hard to start it without it. Jared
>I have a Stihl 290 that starts right up every time. The issue with the Easy Start series is that you have to give up some compression power in exchange for an easier pull of the starter rope. Most Stihl dealers will not recommend the Easy Start saws unless you have shoulder issues.
>Bruce, the drop start is dangerous...enough to get you seriously injured or worse. The saw should always be on the ground, with a foot securing the saw as well as one hand.
Keith, I can agree. I start mine on the ground with my foot on the handle, but have a neighbor who is a woodcutting pro. He drop starts his saw and makes it look easy. I've tried it, and it works, but I'm not comfortable with that technique.
>I've done it hanging in a harness in a tree. It's not something I recommend and requires practice to do it safely. My suggestion. Put it on the ground and stand on it.
>a system where you pull on the starting cord with a steady easy pull rahter than a hard jerk. The easy pull winds up a larger spring that will kick over the motor.
>Remember the 250 is a homeowner saw the pro saws are much better saws look at the 260 with decompression. If you want a tuff saw look at the 290 but its heavy and you would not want to run it all day.
>Good explanation. I guess I knew what it was without knowing it. I have an Echo weedeater with a similar feature on it, now my wife can start it and use it without my help that is good as I really dislike weedeating. Jared
