THE WOODRAT IS BACK!
Tool bender
Tool bender
Tool bender
>I have trouble bending tools when I make them so I usually heat them up which of course wastes fuel. I decided today to make a tool bending jig that works like my mini wire bending jig. I made it huge, 6" by 4" with 3/4" and 1/2" rods. They are space differently so can fit different sized rods and flat stock in between the metal dowels.
I started this because I want to make my own McNaughton style coring tools but also to make it quicker to make hollowing tools. I can bend anything from 1/2" on down pretty easily. 5/8" will probably take a cheater bar. 3/4" will probably have to be heated although I'll bet I can put a bend in it with a long cheater bar.
Re: Tool bender
Re: Tool bender in action
>Here it is in action. I'm bending a McNaughton cutter that is a slightly tighter curve than the one in the background. I'm going to try to put a carbide cutter on the tip when I have time.
Re: Tool bender
Jeff Brockett
>John, looks like it will work good. Be interested in seeing the tip you put on it.
Re: Tool bender
Sean Troy
>Will we see Lucas tools in the near future? :)
Re: Tool bender
Mike Brazeau
>Great idea John, but that is nothing new for you! Your work table must be securely mounted to the floor? Looks like it would be dandy for making curved tool rests too.
Mike
Re: Tool bender
>Mike When I bought the house the metal workbench with metal drawer and the vise were left by the other owner. It is incredibly heavy and solid. I'm not sure how I will move it when I leave but I love that bench. I wish it had a swiveling vise. I've hit my hip on it walking by several times and it's like hitting a bolt sticking out of a train car. It doesn't move at all.
Re: Tool bender
Dick Hines
Re: Tool bender
Dick Hines
>We need better directions , John.
Re: Tool bender
Re: Tool bender
>Dick There aren't any directions. Just put the metal between the bars and pull. One bar restrains it and the other acts as a fulcrum. The bars can be moved to different holes to compensate for material of different thicknesses.
To get a continuous arc you just move the metal 1/4 to 1/2" at a time and bend. I drew the plans on the white board you see behind the vice. Then I would bend the bar a little and check the progress against the drawing. Took about 5 minutes to get it almost exactly like I wanted. Ideally I think I need a larger bar for the fulcrum. I had to be very careful to keep the arc from being more segmented instead of smooth.
I originally designed this to help me make curved tools for hollowing, and I will use it for that but now that I have the McNaughton coring system I am going to make some cutters for it.
Re: Tool bender
Charcoal
jwoodwright
>John,
Wouldn't a charcol grill help to heat the steel first. Kinda align the molecues and assist in easier and smoother bending? John K.
Re: Tool bender
Re: Charcoal
>I have a forge but it takes a while to heat it up and I can't fire it up at all in the winter because I have to take it outside. You also get carbon build up on the metal and have to clean it off after you heat it. If I can bend it without heat it's easier and cleaner. In fact I'm also building a small gas forge which I can fire up in the shop but it's limited to fairly small pieces.
