laser tachometer - thread chasing
Ed Moore in SW VA
>While the subject indicated doesn't suggest it, this is actually a little humorous. I saw a previous post about these inexpensive devices, and decided to get a photo laser tachometer. I think the brand is Neiko.
I inserted the batteries and put a little piece of the supplied reflective tape on the handwheels of two lathes. To make a long story short, I think I have been trying to chase threads at almost twice the recommended speed. Allan Batty suggests about 300 rpm for chasing. Some of my early efforts were probably at 550 - 750 rpm, and maybe worse than that. No wonder I struggled.
At some point when doing a demo if I am asked about the lathe speed I will whip out the tachometer, get a reading, and announce 1127.6 rpm, or some such figure. ;^D
Ed
Re: laser tachometer - thread chasing
Rob Wallace
Rob Wallace
>Ed Moore wrote:
"At some point when doing a demo if I am asked about the lathe speed I will whip out the tachometer, get a reading, and announce 1127.6 rpm, or some such figure. ;^D "
Been there - done that!! Gets a pretty good laugh.....
Hope you're recovering nicely!
Rob Wallace
>Ed I was doing a thread chasing demo for the TAW the other night and using jet mini lathe. I started chasing threads with a 13TPI chaser on a new type of wood. I was having a lot of trouble. I switched to a 20TPI chaser and was really moving fast through the threads. I made threads and then discovered that I had the lathe set to it's highest speed.
I backed it back down to the second slowest speed (which is above 500) and made threads much easier. I am usually using 16TPI and make my threads around 500 rpm unless I'm running up to a shoulder.
I've always wanted one of those Tachometers. I guess I'll spend the bucks one of these days.
GaryG in MD
>$26.95 at Amazon -- sounds like a good thing to have around. ...Gary
