46-460 Delta lathe question
Duane
>I've been considering purchasing the Delta lathe. I like the idea of the reverse switch for sanding. The thought occurred to me, if you have a chuck screwed on will it back itself off the drive spindle? This must be done with larger lathes all the time. I'd just like some theories why this won't be a problem.
Re: 46-460 Delta lathe question
JohnKyler
>My understanding Delta has a special deal with Nova that the chuck is in a package and the chuck has modifications that address the reversing. Got this last week from my Delta rep.
I think where I work we have some ordered (10 packages) but please contact your local dealer and they can get them...
They should be able to get you set up.
John
>I don't know anything about Delta and special chucks, but....
The chuck backing off when the lathe is reversed can be a problem. I have a DVR lathe and it reverses with the touch of a button. It has a soft start feature and does not snap to full speed instantly. In my case, if I screw a chuck on very gently with a heavy blank it sometimes backs off if I start the lathe in reverse. It has happened several times, but not lately. As I recall, its not really exciting. The chuck and blank don't rotate, but move to the right and fall off, clunk, onto the ways. Never had one fly around or anything wild and dangerous.
OTOH, If I give the blank/chuck a slight "snap" as I screw it on and seat it and then rough the blank or work on it in the forward mode, I have never had one unscrew while reversing it to sand.
In addition, most chucks have a set screw in them that allows you to set it against the shaft and basically lock the chuck onto the shaft. If you are concerned, use the set screw and you will have little to worry about.
As an aside, There have been many threads here about chucks that are very difficult to remove. My experience is that that little snap I mentioned about setting the chuck is more important than you might think. If you put the chuck loosely or partly onto the shaft and let the lathe spin it up tight or start cutting and have it set itself, you will have much more trouble getting it off. I'm thinking there is a relationship between the force used to install it and the force necessary to remove it. So, set it firmly but gently. And yes, you can use one of the plastic washers...but I'm just sayin...
keith zimmerman, Normal, IL
>I've had my Delta 46-460 since May and have not encountered this issue with my Talons. I also, as Barry said, "snap" the chuck onto the spindle as I screw it on. The Talon has a setscrew hole in the collar to use for this but I haven't used it. However, if I were ever to encounter this issue, I would definitely fit the correct setscrew and use it.
So far, so good.
keithz
Duane W. Brighton, Mi
>Thank you guys. I was trying to justify my not buying this lathe. Thankfully you have shown me the error in my judgement and I'll have to buy one. :)
