ADVERTISE HERE - FREE TRIAL
Lathe height question.
Scott Burr in Ben Lomond CA
>As I slowly move along in getting my lathe set up, I was wondering something. I'm 6 feet tall, what would be a good height for my lathe?
As I get older my back hates being hunched over for long periods of time, but maybe one needs to be hunched over a bit to control tool holding and handling during turning.
Thank you and have a fun and safe holiday.
Re: Lathe height question.
David Walser
>The general rule of thumb is to have the "center height" of your lathe match your elbows. In his new book, Ellsworth on Woodturning: How a Master Creates Bowls, Pots, and Vessels, David Ellsworth says the elbow height rule only applies to spindle turning. For bowl turning and hollow firms, he says the lathe should be about 3 or 4 inches lower.
These are just rules of thumb. The correct answer is the lathe should be at a height that's comfortable for you and your style of turning.
HTH
Greg Haugen
>Scott,
For spindle turning, I'd go by the "elbow rule" or a little bit higher.
For bowl turning, I definately agree to the lower height. Turning much more "from the hip".
Another consideration are your tools. A while ago I bought a set of hollowing tools with an armbrace handle. I didn't like the handle at all since it pointed out my lathe was too low for it's use. After I raised the lathe, I liked it much better. Especially tools like an armbrace handle effects where the spindle will be or you'll have to slump down a fair amount to use it properly. For hollowing with a straight handle, it's much easier to turn "from the hip".
After a few hours, you'll know if you have to raise its height.
The right height is where YOU are comfortable.
Sean Troy
>I have mine set and bolted to 6x6's. Spindle height is around 50-51 inches. I'm 6'3" and have a bad back. Less bending is better for me.
Barry Elder
>I find that having the headstock centerline at about elbow height is much less tiring for me. Has nothing to do with my back as it is fine.
Bernie Weishapl
>I am 6' tall also and my elbow measurement is 42 1/2". I have my lathe set at 47". I am comfortable there and no bending.
keith zimmerman, Normal, IL
>Both my Jet mini on it's stand and my Delta midi on a custom bench are set to my elbow height. I'm a rather short guy (5' 8 1/2"), so I built the bench short with 26" legs, specifically to get the spindle to my elbow.
This is what works for me.
keithz
Re: Hey Keith, we're not short, but .....
Jamie Donaldson
>...about average height. That means we're at the peak of the height Bell curve, and many shorter and longer folks are less than average! It's all in how you say it! I have Studly , my main hollowing Stubby, about 3" higher than the Woodfast that I use for most other work.
Dick Hines
Dick Hines
>Who are you calling less than average?
I stand corrected, Jamie
>So we're at the top of the bell, huh. That's cool. Finally, something where average is at the peak.
Re: Thanks All. You guys are great!
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>Elbow level is appropriate for most of my turning. Never higher. If I need to be a little lower, i just take off my shoes -- works great.
Rob Wallace
,,,Just be sure to never drop a skew or gouge!
Rob Wallace
