I learned something in a demo last night
Steven Antonucci
steve antonucci
>I was the demo guy for the WaterGap Woodturners club meeting last night, and I decided to do a long thin stemmed goblet. I have turned a couple, so I know I can do it. I grabbed a piece of maple before I headed out, doomed before I ever turned on the lathe.
Most people would have probably thrown out the piece of wood as soon as they realized one size of it was starting to go soft. I figured that I would eventually get past the slightly soft spot, but it never happened. Half wood, half mushy most of the way down the log.
Decided that it wasn't terribly important to worry about surface quality and cut the step to about 1/8" half way down. When the lathe spun down, I noticed that the cup had stopped moving and the end was still twisted. Lowered the speed before restarting, and restarted without incidence.
Finished cutting the ENTIRE stem, which was 10" or so, and I had undercut the foot to a 1/8" supporting connection, when I asked on of the guys to turn the lathe off for me. SNAP. The rundown on the Oneway twisted the head off of the goblet. Everyone had to chuckle since I had cut the entire length of the goblet with a skew and without incident, and was foiled by powering the lathe off.
Like Yogi said, "It ain't over until it's over"
Steve
Re: I learned something in a demo last night
I did the same thing but was using the tailstock
>with a piece of soft foam to keep the goblet from whipping. It worked perfectly until I turned off the lathe. It snapped the stem as it spun down.
Steven Antonucci
No foam, but the Oneway cone instead
steve antonucci
>Now I know why Jimmy Clewes does the demo with no support...:-)
S
Re: I did the same thing but was using the tailsto
Chet Gelnett
>I don't turn my lathe on and off with the switch anymore, I just use the speed adjust to stop and start. It seems to be a smoother start-up and stop. Plus I find it is not as scary when there is a big chunk of wood on the lathe and you hit the on button and then remember it is set to high speed from the night before pen turning.
I learned this trick from Gene.
String steady, mounted on tailstock
Doc Green
>I find a string steady to be quite effective in stabilizing a tall goblet or the end of a long spindle, and the twisting problem is eliminated. The one I use mounts in the Morse taper of the tailstock ram and can be set up at any time, in just a minute.
The bowl of the goblet fits (without touching) inside a cup that mounts on an adapter turned to fit the Morse taper. The string is wrapped around 4 nails driven into the rim of the cup.
The loose end of the string is wrapped around a small block epoxied to the side of the cup. A clip for binding papers holds the string tight. This avoids having to tie a knot. Almost any string will work, and the string runs straight across the stem of the goblet without wrapping around the stem. A waxed string is not required.
This is my implementation of an idea that's been around for a good while. If you have questions, email me directly. ~Doc
Another picture
Doc Green
>This shows the adapter removed from the cup. It is turned from a piece of soft maple. Scrap pine was used for the cup, and a Forstner bit was used to hollow the cup.
Incidentally, turning the Morse taper is not hard because the fit doesn't have to be perfect. After all, the parts do not rotate and practically no force is exerted on the cup in use.
I bored a 3/4" hole in the bottom of the cup and then turned the end of the adapter to match the hole. If the fit gets loose, a bit of water applied to the adapter will tighten it up again.
