Presentation & Preservation
charlie belden
>I was married to a picture framer. She had a pet peeve about a significant shortcoming in the college curriculum of art colleges - NOTHING, or almost nothing, was taught on Presentation or Preservation.
The nicest painting - on a piece of fine water color paper, or on a stretched canvas - - SHOULD NOT be the end point for the artist. With good mat selection - color/texture - layers - border width, etc., and the right frame - even a fair to middlin piece can be made more attractive and pleasing on the eye. Presentation - good presentation - can make or break even the best works.
And when it came to Preservation . . .
A beautiful water color - on paper that wasn't acid free - would drive her up the wall.
"Those beautiful colors - will lose their color in a year or two - and will be lost in 20 years."
If the frame had glass - glass touching the piece, or its mat - NEVER!
Is the back of the framed piece sealed off - with acid free paper? If not it should be.
UV glass? Helps - but any piece exposed to light, especially direct sunlight - WILL fade (ok so Cherry wood gets darker).
In the turning world Presentation and Preservation seems to be almost totally overlooked.
A really nice platter turned perfectly of a fantastic piece of wood with wonderful subtle details and a finish to die for - displayed in a so-so if not downright ugly stand - and displayed where all you see is reflections of the space in which it resides - the finish acting as a mirror.
An unebelievably thin walled hollow form placed on the mantle - of a fireplace - that's used often.
A segmented piece with a fascinating pattern or shape - directly in the air flow path of the heating and cooling system duct outlet.
A delicatly pierced piece - set too high to see - or reach - up in the place where hot air rises and stays.
A display shelf - filled with gorgeous little lidded boxes - ALL sitting directly on the shelf - all their bottoms at the same level.
CA glue. Amazing stuff. How long it will do what it's doing now - holding this to that - or acting as a high gloss finish - who knows. It hasn't been in use long enough to tell. Will it crack and crackle?
What will it do to the wood - over 20 or 30 years?
That necklace stand - with the 30 pieces - held together with glue? What happens if one of its elements should break off? Could it be repaired/restored - wthout a lot of time and effort - or at all?
If you've thought about Presentation and/or Preservation - what have you come up with that others might benefit by becoming aware of it?
What questions do you have about these subjects?
Suggestions, comments, insights?
