For Scott Burr
For Scott Burr
Steve Kubien
For Scott Burr
Steve Kubien
>Hey Scott,
I have no idea what you've got in the way of turning tools but...
Ok, seeing as you are a hand-tool guy, you obviously understand the cutting edge of a plane or chisel. You also understand sharp. With that in mind, I think a skew chisel is perfect for you. Just look at it as a plane iron... Skew the cutting edge, ride the bevel (same idea as have the toe and heal of the plane in contact with the work) and go at it. Keep the pointy end out of the work.
Take a look at a Richard Raffan dvd. There you'll see how a skew is used. Wonderful tool. Too bad too many turners are afraid of it (or p*ssed off at it).
Have fun,
Steve
Re: For Scott Burr
Hi Steve, thanks...
Scott Burr in Ben Lomond CA
>I have zero lathe tools, heck I don't have a chuck yet. I still need to get pulleys and a jack shaft, get the motor wired, power switch etc. Then I get to learn how turn somehow. This is a BIG learning curve for me. Here's the lathe as it stands now. Nothing but a live center.
Thank you for the info!
Scott
Re: For Scott Burr
Re: Hi Steve, thanks...
keith zimmerman, Normal, IL
>I started with just a drive center on my first lathe...and no morse taper. It was an adventure to get a center for the tailstock and to be able to even mount a blank on it.
Good luck with the lathe. I got through the learning curve, so will you.
I'm looking forward to seeing the first piece that comes off.
keithz
