Buffing Question
Sean Troy
>How many of you skip the first wheel in the buffing process and go straight to the white diamond and then wax wheel? Does finish make you decide? My question is about a lacquer finish.
Buffing Question
Sean Troy
Re: Buffing Question
Doug Turner
>I don't skip the first buff. Even sanding to 600 grit before using lacquer there are minute sanding scratches that the buff removes and this improves the final finish. Try it both ways and a sample piece of wood and you will see for yourself.
>I depends on the wood color and how deep the grain is, not the finish. If you use the white wheel on Walnut the white will fill the pores and it's very hard or impossible to get out. The opposite is true with Ash. The Brown wheel will fill up the pores of ash.
If your finish is thick enough so the wheels can't fill the pores then you can easily go through them all.
The brown wheel is supposed to polish out any imperfections in the finish. If your finish is good enough you may be able to go straight to the white compound. Satin finish can often be done with just the white although I usually start with the Brown anytime that I can.
Sean Troy
>Yeah, I'll be using all three wheels. My finish's just are not that good to be skipping buffing steps.
Re: Buffing Question *LINK*
Russ Fairfield
>Use a stiff scrub brush to clean the buffing compouind and wax out of the wood grain.
Wax loves a harsh scrubbing. It will clean it out of the grain, and remove the excess wax from the surface. The remaining wax will be compacted, and last longer with a higher gloss for doing it.
The link goes to my website and probably more than you ever wanted to know about wax, and I'm not finished with yet.
All About Wax
Bruce McElhaney, Spring Lake, Michigan
>I almost never skip tripoli, but sometimes do skip white diamond for reasons previously mentioned. Also, I rarely use carnauba wax any longer as it can leave water spots if it gets wet from rain while doing art shows. Renaissance wax is now my preferred wax.
Sean Troy
>Hi Russ, I've visited your site a lot of times and never left because I was bored. I really enjoy all the information you have and share. Thank you.
Sean Troy
>Bruce, where do you buy your ren wax? I have a little circle of it I use on pens once in awhile but would love to find some larger size quantities if the price is OK. I also heard somewhere that there is a similar product that is less expensive but works as good. Do you apply it to the buffing wheel like the carnuba? Thanks for any info.
Scott in SoCal
>Bruce said exactly what I was going to say. I always use tripoli, only use white diamond on pieces with no pores or a film finish, and I don't use carnuba at all, it is a poor choice for a top coat.
I'll add that leveling your finish before hand is really important. The buff will polish the existing surface, but it won't remove any of the ripples or orange peel or other imperfections. Wet sanding with micromesh or 600/800 grit w/d paper makes the finish flat and smooth. Good quality 0000 steel wool works well too (not the home depot stuff, I use Liberon). Aim for a uniform dull white appearance with a perfectly flat surface. Then take it to the buffing wheel, and it'll come up to an amazing shine. The leveling is what gives the surface the amazing soft feel, your fingers can detect imperfections your eyes can't - variations quite smaller than .001" can be felt by most everyone.
Chet Gelnett
>1952 and high school!! whoo did not think wax was invented yet.
Great writeup on wax, thanks
Chet Gelnett
>My Renaissance wax dried up. Had the lid on tight and only used it once. When I went back to use it the second time all that was left was a small dried up postage stamp that was very hard. Have not tried it since.
Paul Zerjay
>I would also like to hear about the application process on Renaissance wax.
>Sean, I got my Renaissance wax at Woodcraft. They had a sale on it a while back, so I bought a couple of large cans. It goes a long way. I put a very thin coat on and usually rub it out with a cloth. I have also buffed it and that works well also. I really like the fact that when Ren. waxed objects are handled (like at art shows) no fingerprints are left behind. Can't say that for Carnauba wax.
Renaissance wax restorer
Ed Moore of SW VA
>Chet,
When I asked on WC about a good solvent for Renaissance wax, Russ Fairfield suggested low scent mineral spirits. I got some from Lowes and stirred it in after it sat for a little while and the wax is as good as new. I used it yesterday and that is four or more months later.
Ed
White in the grain, and water spots on Carnauba??
Russ Fairfield
>Read again what I said about a scrubb brush. A hard scrubbing with a stiff brush solves both problems. Use a natural bristle brush because the ends of the bristles are softer than the sharp cut ends of nylon or other plastic bristles. The brushes cost about $2 at the grocery store.
White stuff compacted into the pored of a dark wood is a sure sign that you are using too much of the White Diamond. The same goes for the brown stuff left in the grain of a white wood when buffed with Tripoli. However, a thorough scrubbing removes all of the residual from the wood pores.
The Tripoli residue is harder to remove because the carrier is tallow (animal fat). You might have to use an old tooth brush and a little Mineral Spirits to remove it from deep voids in the wood.
The problem with Carnauba and water spots are 2. If it is a pure hard Carnauba applied with a buffing wheel, there is too much wax on the surface and the wax particles are not compacted as tightly together as they could be. If the surface feels like wax and is sticky, there is too much wax. Buffing with the stiff brush will both remove the excess wax and compact it on the surface.
The only reason that Renaissance works better is that the Microcrystalline wax is a smaller particle, and it therefore compacts better than the larger Carnauba particles and there is less chance for water to get under it and ruin the gloss.
To those who don't believe that scrubbing wax with a stiff bristle brush, I can only say - Don't knock it until you have tried it. The French still use wax as a finish, and they scrub it with a brush made from Goose Quills. That is a pretty harsh treatment, but the wax loves it.
The other reason that Carnauba fails when we use a paste wax is because the paste is a combination of Carnauba, and softer paraffin or beeswaxes to make it easier to apply. You might as well be using plain paraffin or beeswax. Again scrubbing can improve the surface, but it will never get the same quality as a pure Carnauba that is applied with a buffing wheel and then buffed with a stiff brush.
>Chet, I've used Ren Wax, off and on, for several years and never had any dry up on me. Can't say the same for other waxes though . . . Glad to see Ed come up with a good solution for restoring wax.
The specific product I used ...
Ed Moore of SW VA
>was Crown "Low Odor Mineral Spirits" and I got it at Lowes. I put a little too much in at first and it was a little soupy, but the consistency is fine now.
Any credit for this would be Russ Fairfield's. ;^)
Ed
Re: The specific product I used ...
Chet Gelnett
>Great Thanks I will have to try that. I do have the Renaissance Wax in the little white 1/2 container. Maybe it has a creak somewhere. I never threw it out since it cost so much.
Don Pencil
>Sean,
You can easily buff through a lacquer finish with white diamond so go easy. Tripoli on a lacquer finish should not even be considered.
We have a new product call "PL" and is made for just that purpose and is getting amazing results and reviews from users. Works great at low speed (700-900 rpm), lacquer remains cool and buffs out to a glass finish very quickly.
I would not buff with anything prior to applying the lacquer as the wax/grease formulas used to carry the abrasive will be a problem for you. Just sand well to whatever grit you normally would have before applying lacquer. Apply several coats of lacquer and then buff it out.
Be Well,
Don Pencil
Re: "PL" Question
Mike Jones in Redding, Ca.
>Don, could not find this new product on your website!!??
Re: "PL" Question
Bill Stehman
>Don's wheel and compound is the best you will ever find for a lacquer finish. Slow speed buffing is the key.
Marvelous results.
>I've been using Tripoli on lacquer for years. I burned through on the first few I did but then I learned to let the lacquer harden for a day and I buff as slow speed. Works just fine.
Russ Fairfield
>If you are having a problem buffing through lacquer, you are buffing too soon.
Be aware of how lacquer dries. It forms a skin that slows the evaporation of the solvents under it. That means it dries slowly, and the thicker the surface film, the longer it takes. As long as you can smell the thinner, it hasn't dried. How long is "as long as" depends on atmospheric conditions, but it can be several months in most cases.
As John said, always wait at least a day and buff slowly and lightly. Waiting longer is even better, and waiting a week will allow you to buff without problems unless you get really aggressive with the buffing wheel.
Re: "PL" Question
Sean Troy
>How much compound comes with each order?
Re: "PL" Question
Don Pencil
>The main page has a big bright yellow banner that leads to the link below.
http://www.donpencil.com/PL%20BUFFING.htm
