OK, OK... The last of the motor questions. Curly!
Scott Burr in Ben Lomond CA
>I owe you one. Thanks for all your help.
So being a noob...
If you had 4 speeds to work with what would pick?
Re: OK, OK... The last of the motor questions. Curly!
Steve Kubien
Steve Kubien
>Start slow generally. Things are less, ummm, exciting, that way.
What are you going to turn? I think you said originally by I CRS!!!
>I have a variable speed, so I don't count. But I think part of it is dependent on your available power - I just don't know how much.
Generally I like slow for roughing bowls - say 300-500 and faster for roughing spindles - say 700-1000.
I like a medium speed for cutting on bowls - 600-1000 and slightly faster for spindles (1200-1500).
I like a faster speed for sanding on bowls and spindles.
However, I often start at about 1200 for spindles and go up from there.
So my thoughts would be
350-500 rpm
700-1000 rpm
1200-1500 rpm
1800-2200 rpm
My $0.02
Bill Howatt
>When you are learning always start with a slow speed. You quickly will get "educated". The basic rule is the larger the diameter the slower the speed. If you think about it, a 6" diameter piece at 500 rpm has the same amount of cutting surface going by the tool each second as a 2" diameter piece at 1500 rpm. So the cutting rate in feet-per-minute is identical.
Blanks that are out of balance, typically bowl blanks, offer even more reason to keep the speed down since the effect of the non-uniform weight distribution is amplified by higher speeds. Starting a lathe at high speed with a large diameter, unbalanced blank can be a saftey hazard. Always keep out of the line-of-fire (in front of the blank) when first starting a lathe with any blank mounted.
Bill
Curly Smith
>Your lathe originally had, by your first note, speeds of 400, 765, 1345 and 2275 (and are largely what JL recommended) so I'd look at trying to match that, erring on the downside. For example, if you had the choice of 440 or 360 then I'd go with 360.
Those speed ranges look good for a starting turner but as you get better you're going to want a higher top-end speed. You want to turn at the highest possible safe speed to get the cleanest cut and if you're going to be making pens or other small items then you're going to want a high end speed of 3000-3500.
I should have mentioned this before but if you're going to build the jackshaft then you don't have to limit yourself to 4 speeds. There's no reason that you can't put a step pulley on the motor end of the jackshaft to give you even more speed ranges or to simply install different sized single pulleys. If you install a 2" pulley on the motor, a 4" on the jackshaft, and (2) 2,3,4,5 step pulleys then you'll have a top speed of 2188. By swapping a 3" for the 4" then your top speed increases to 2916. Conversely, swapping a 5" for the 4" decreases your low-end speed to 280.
If you opt for a step pulley on the motor end of the jackshaft then you'll need to make sure that the shaft is long enough to allow you to move the step pulley to keep the groove you're using aligned with the motor pulley. You'll also need to factor in some extra motor mount adjustability to properly tension the belt (the same holds true if you use different diameter single pulleys).
The advantage of installing a jackshaft is that it gives you a lot of options, the downside is that it gives you a lot of options.
Start Slowest Of Course
Texian
You got it! Thanks Everyone!
>Guess I need a spindle upside the head to figure this out sometimes. With pulleys available, I could do some serious harm. My last calculation I could go from 350-4375 RPMs... Scary to me, big time.
While I form a spreadsheet to figure all this out. I'd like to thank you all for your input. It is greatly appreciated!
Next up: motor wiring!
Thanks again!
Hi Steve, mostly...
>Chisel handles to begin with. Then some spindles for some dinning room chairs. Then God only knows. Just need to start slow, keep the body & head intact and jump over what seems to me to be a large learning curve.
Looking forward to it.
Thanks!
Steve Kubien
Re: Hi Steve, mostly...
Steve Kubien
>Hah! That's what I started with...chisel handle for an old Swan. Never did finish it and never touched another flat-work project again! The Vortex is strong Scott. Give in to your true feelings to turn, turn, turn....
I need to go to bed now.
Steve
