For those with 1/4" round skews
Paul Zerjay
>Do you find it hard to keep the cutting edge centered when sharpening? I don't seem to have a problem with my larger skews, but this little 1/4" one gives me fits.
Re: For those with 1/4" round skews
Russ Fairfield
>Try shutting off the tool grinder and sharpening at a slower speed when the wheel is spinning down. Even a 1500RPM grinding wheel will take off too much metal too fast for these little tools.
Greg Haugen
>Think of sharpening as "dressing the bevel" not "grinding the bevel". A light touch is key to any sharpening. Far too often I find students are too heavy handed while sharpening. A light touch will also not "blue" the steel on the finer grit wheels, as long as they're properly dressed. Double bevel tools, like a skew, need repeated processes, "what is done to one side must be done equally to the other." Often, we prefer to or are more comfortable sharpening one side so we do it little longer than the other without thinking about it. Also take advantage of honing skews. No need to grind every time. Use a diamond hone until the honing lines, areas of the hollow grind that are being honed, begin to get too wide (depending on the size of the skew a strong 1/16" to an 1/8" is getting too wide)-then regrind.
Just my 2 cents.
Greg H.
>What greg says is correct as far as sharpening. On the other hand I had a skew that I sharpened many many times and it gradually got off center. It didn't seem to matter any at all in how I used the tool. It cut just the same. The wood doesn't know it off, it only sees the total angle and the length of the bevel. When I notice it is getting off center now I just pay a little more attention when I sharpen to pull it back onto center.
I have a bowl gouge that has one wing higher and the other wing way longer. I use it the same way as my tools that are balanced. It hasn't made much difference there either. It's more important how you use the tool than the shape of the tool.
Now a diamond parting tool is a different animal and must be sharpened exactly even.
Re: Greg rightly suggested the fine ....
Jamie Donaldson
>....diamond hone in between grinding sessions, and when I do have to reshape at the 120 wheel I use the side of the stone for better vision and control. I know, don't grind on the sides of a wheel, but there is virtually no pressure and no danger in this exception to the rule!
Paul Zerjay
>I agree with you in that the wood doesn't care what the tool looks like. I don't really care either. In fact, it's almost helping me out, because I am better at turning one side of a bead than I am at turning the other side. With the extra length of bevel on the one side of the skew, I seem to have less skating. Nerve racking at times, but becoming an enjoyable tool.
Grinding on the side . . .
Doc Green
>I also sharpen my skew using the side of the wheel. There's no substitute for being able to see what you're doing. ~Doc
Steven Antonucci
Use a belt sander
steve antonucci
>You can use a 400 grit belt and no risk of the belt exploding. Works great...
Steve
keith zimmerman, Normal IL
>Using my Sorby ProEdge sharpening system, it is easy to sharpen any skew. It came with a jog that is preset to give me the correct bevel and edge angle. With a 400 grit belt, it works great. I use a diamond hone between sharpenings.
keithz
Jorge Castaneda~Downeast Maine
>Hi Keith,
That Pro-edge sound s good, did you find it on this side of the big pond? Remands me of a 1" Belsaw I had in the 70's that I used to sharpen everything, even table saw blades.
Thanks
Jorge
keith zimmerman, Normal, IL
>I purchased it from Klingspor.
keithz
Thanks!
>Good to know.
belt exploding
Dave Peebles Lyons, Ohio!
>I have seen this happen once... It was at an all you can eat buffet. I was two tables away, and thank goodness the salad bar sneeze guard was between his table and mine. Or, it could have been nasty. :)
Sorry, but it has been a long day.
Dave
Steven Antonucci
LOL
steve antonucci
Steve Kubien
Re: belt exploding
Steve Kubien
>"Just one mint? It's wafer thin!"
