Segment cut-off sled
Doug Reynolds in Seattle
>I have seen some examples of a cut-off sled to use on a table saw to cut segments for segmented turning i.e., Dubby but, have never found a plan for one I can make. Can you direct me to a source?
Re: Segment cut-off sled
Russ Fairfield
>Flat Miter Sled
http://www.turnedwood.com/framesled.html
Compound Miter Sled
http://www.turnedwood.com/compsled.html
>Wood magazine also has an excellent one in an article. Maybe you could find that by going to their website.
Rich Pearson in Mill Creek, WA
>Hi Doug,
I,ve built several precision sleds and would be glad to show you a few things I've done to get repeatability. If you've a mind to come out to Mill Creek (exit 186 off I-5) near Lynnwood, just drop me an e-mail. Be sure to remove the NOSPAM from my address!
ebd
>I used Kevin's ideas as a starting point (referenced above) and made some improvments that I believe improve accuracy, repeatablilty, and ease of use (at least for me). I could email you some pictures with a brief explaination or post it here if you like.
One thing I would strongly suggest. Make a sled for a DEDICATED number of segments. Don't try to make one that can do a variable number of segments. It just takes WAY TOO LONG to get the angle PERFECT by making test cuts. Close simply just sucks. You want to be able to cut and glue with no muss or fuss and be confident that it will fit PERFECTLY.
I (for now) exclusively use 12 segment rings (http://www.eskimoblueday.com to see). I also made a 45 degree sled to cut sides for the frames I make for pictures and stained glass Pannels. Whenever I pop a sled onto the tablesaw I can be positively sure that I will get perfect 4 sided or 12 sided glue-ups EVERY TIME.
