>I am doing a craft show this fall and it was suggested that a few of pedestals to highlight some of my work. Anyone have an idea for cheap, easy, stable pedestals that will do well in a craft show?? May be too much to expect but maybe someone has come up with something.
>My friends use pedestals made from MDF and sized so they stack inside each other. I think I would try something a little more weather resistant.
I tried using Sonotubes, the cardboard tubes for pouring concrete. I painted them with Gesso and then painted them the color I wanted. They didn't take abuse very well and had to touched up just about every time I used them. I cut the round tops on the bandsaw. They did look nice.
For the past few years I have "made" pedestals for showing my work at the Iowa State Fair Art Exhibition by using inexpensive round lidded cardboard boxes available at Hobby Lobby or other similar craft stores (between 6 and 10 inches diameter). I then buy (at Walmart) a can of specialty spray "paint" that simulates the look of artificial stone/granite and do an even coating over the outside surfaces of both the box and the lid. For each box purchased (costs about $2 to $3) you get two "pedestals". For about $10 or less this takes virtually no time (or much work) to do; I've made these in a brown/tan "rock" color and another set in grey. I use the pedestals over and over as needed. There are a range of sizes of boxes available so you can match the pedestal to the scale of the piece that will sit upon it. These are simple, inexpensive, and the stone look goes well with wood grain and turned items.
I put T-nuts under the bottom corners - and a short carriage bolt into the T-nut for leveling.
Would NOT be good to have a piece on a slanted
surface - especially if what it would fall on is HARD - like concrete or asphalt - or even tile.
Nested tables - with "bridge" pieces - are nice for
displaying things - and because they nest, don't take up a LOT of room. Made of a light wood - like redwood which we in California have plenty of - they don't weigh a lot either. If you have a Festool Domino, and go with loose tenon mortise and tenon joints you can make them pretty quickly and easily. You can pretty them up with "cloud lift" aprons and a bead or two on each leg.
The attached examples are out of redwood 2x2s from Home Depot and redwood fence boards - old weathered fence boards.
>There are many ways to go with pedestals. Particle board is is stable but heavy. I wanted lighter pedestals that were easy to carry and stack together. So I made my art show pedestals out of 1/4" Baltic Birch plywood. I used solid pine tops with routed groves to fit the base and allow a 2" overhang all around. The sizes are 12", 11" and 10" squares in order to stack inside each other for easier transportation. Pedestal heights also varied from 24" to 40" for a more interesting display. They are painted black with a final coat of clear poly.
A friend made some out of 1/4" wall panelling and used cloth hinges so he could fold them flat. He also used solid wood tops with a routed grove to stabilize the pedestals when set up. His pedestals can hold heavy pottery with no problem. Good luck.
>Thanks all for the replies. Lots of ideas here and I guess I'll just have to choose one and go with it. I'm leaning toward the sono tubes. Jennifer's display looked nice, and the construction seems fast and easy. I have made a couple of knock down shelving systems, one in cherry and the other butternut. I just never thought about doing pedestals.
>Watch what brand of sono tube you buy. Some are coated with what seems like a waxy release. I'm sure that is for the inside surface only, but it gets transfered to all the surfaces in some manner, and paint won't like that. I also wish they didn't have so much overlap in that paper wrap. It really leaves a nasty spiral seam for the use you want. My lumber yard (if you still have those sort of things around you) has the best selection of sizes.
