Have a question? Ask Woody!
There's a Monster in my house...
keith zimmerman, Normal, IL
>I bought a Monster Hollowing system from Randy Privett while at the symposium. Well, I've had it for a couple of weeks now and can now show the first hollow vessel to come off it. I learned a lot about the tool with this first vessel, but at least I didn't make the inside larger than the outside. I managed to get pretty uniform wall thickness of about 3/32", but there are lots of ridges and I was afraid to go any thinner. It's going to take some time to figure out how to properly set the laser, but that will come.
Anyway, here it is. It is turned from Spalted Hackberry and is 5 1/2" tall and 3 1/4" in diameter and I managed to keep the opening to 1 1/4". So far, there are just a couple of coats of Waterlox on it.
Any and all comments are welcome...and thanks for looking.
keithz
Re: There's a Monster in my house...
charlie belden
>To smooth things inside - change to the carbide "wheel" cutter. MUCH less aggressive. For me, making light "pull cuts" seems to be less risky than "push cuts".
Finding a grip that's comfortable for you - that gives you fine tip control will be a matter of practice and trial and error. Takes some getting used to - pulling and pivoting at the same time - but if you remember that this thing - regardless of the tip - is mainly a scraper - much of what you know about using a scraper is applicable.
The best "measuring gauge" you've got - are your ears. When things get thin, you can hear how aggressive the cut being made is - a soft "swish" is a VERY light scrape - a louder one - a heavier scrape.
The beauty of a good captured hollowing system is that it basically eliminates the Clenched Jaws, Tight Neck, Shoulders Up Around Your Ears, White Knuckle Grip Thing - leaving you to listen carefully and FEEL the cut.
With some practice, and some acquired knowledge of which tip to use when - and how - you'll be hollowing through a 3/4" opening in the near future. Randy's HSS cutters come LONG. Hopefully you ordered some extras. Cut one in half and grind two shorter versions to suit your needs - and if you grind BOTH ends - you get FOUR cutters for the price of one.
The Monster (in my case the MiniMonster) is - to use the vernacular - AWESOME. The only improvements I can think of are:
1. better, easier to secure, locking handles for the laser support system
2. a Goose Neck option to put the tip of the cutter in line with the centerline of the tool shaft.
You'll find all sorts of ways to use The Monster. Enjoy the journey!
Marc Phillips
>Excellent.... really an attractive piece... great job!
Russ Fairfield
>Charlie said, "The best "measuring gauge" you've got - are your ears. When things get thin, you can hear how aggressive the cut being made is - a soft "swish" is a VERY light scrape - a louder one - a heavier scrape."
I have always been told that you can hollow by sound. I have excellent hearing, but must be tone deaf. I never hear any difference until the sound gets louder because the tool has come through the side.
My fingers aren't educated either. The only thickness I can "feel" is when they touch each other, and I know the wood is too thin.
charlie belden
>Actually, your sense of touch is quite sensitive. If you run your fingers over two boards joined edge to edge, you can feel a difference in heights in the 0.001" or better range. Your teeth are even better. You can feel a grain or grit that's in the microns range.
As for sound, mount a blank, rough to round, then INTENTIONALLY turn through it in progessive passes. You can SEE what's happening as you listen to what's happening. When you can connect info via TWO senses, eliminating one of them seems to keep the other one in tact. Turn one "step" through while watching the cut. Then do another "step" and turn it - without looking at the cut. A half dozen to a dozen practices like that and you'll start developing that listening skill - in spite of what you THINK you can or cannot do.
>Oh, believe me Charlie, I know about the sound of the wood. This is just the first system I've had with a laser to get used to. Before buying the Monster, I did some hollowing on a Kelton Hollowing rig without a laser, but mostly by hand with my Kelton hollowers, either in a handle or a Don Pencil armbrace. I've learned about the sound the wood makes and am very attuned to it.
When I teach about hollowing, I always start hollowing by hand so the student can get used to feel of steel on wood and hearing the sound of the tool as the walls get thinner.
keithz
Re: Gives a new meaning to........
Russ Fairfield
>.... letting the wood talk to me.
Texian
>Nice piece Keith! Love that spalted hack. Some would suggest rounding the bottom edge into the bottom to give the piece a bit of "lift" from the supporting surface. The laser adjustment will indeed become easier with practice.
>Many years ago a turner said he hollowed by sound. I've tried, I can't. Maybe if I had a wood that was very consistent but apparently the wood I use is somewhat inconsistent in it's vibration because just like Russ said. I think I'm doing fine and the wood seems to be the same sound throughout but when I measure it varies in thickness a lot.
I had the same problem to a lesser degree using light. Some woods will hollow perfectly using light and checking the density through the vessel and others, especially if the wood has varying color such as box elder, will not transmit light the same way.
I use lots of bent wire gauges and will still occasionally cut through one when turning very thin. The laser has worked best for me but only when you stop and adjust it frequently.
To clarify about the sound of the wood
>I'm not saying I hollow by sound. All I'm saying is that as the walls get thinner, the pitch of that sound changes and I can hear it.
keithz
Richard Fulner
>I have a mini monster and like it very much what i would like to find would be a way to make the adjustments with some sort of screw michism any one seem one
