uses for Thompson detail gouge?
GaryG in MD
>I didn't want to hijack Mike's post below, so let me ask here...
What do you use your 1/2" Thompson Detail Gouge for?
Please note that I am not asking about the Thompson spindle gouge, and not about the Thompson shallow detail gouge.
The tool comes with a pretty steep bevel angle of about 45%.
My Jet 1236 with the stock banjo and tool rest has a fairly limited vertical position -- can't get it very high or very low. I think that's been limiting my applications, but you tell me.
So what cuts do you make with it and what items? Handle level or very low? Strictly end-grain work or anything with side grain? etc.
Thanks, Gary
Re: uses for Thompson detail gouge?
>Gary I use the detail gouge for almost everything that I used to do with a spindle gouge. I have mine sharpened to 40 degrees. About the only problems I have with it is when I want to cut a bead on the face of a platter or one of my mirrors. The handle will be to low and forces me to have the tool extended beyond the tool rest too far. For those cuts I raise the tool rest a long way above the center line. This lets me cut with the handle closer to my waist which is more user friendly and the cutting edge isn't as far over the tool rest.
I now have 2 detail gouges, a 3/8 and a 1/2. My other spindle gouges including one of Doug's pretty much just sit there now.
GaryG in MD
>Thanks John; that's good input. I find myself using my DT 1/2" bowl gouge on spindles more than the detail gouge because of the steep bevel on the latter. Does that make sense to you? Do you use a BG on spindles? Outside? Inside? What are the tradeoffs from your point of view? Thanks, Gary
>Gary It takes a little getting use to , to use a shallow angle spindle gouge. I remember many years ago I had a spindle gouge that I just could not use without catch's. I re-gound the tip to a 45 or 50 degree angle and it was much easier. This is why a bowl gouge seems easier. The tip is usually around 55 degrees and it's just a little more comfortable to use. Mostly because you use it a lot.
When you practice with the shallower angle detail gouge you will get comfortable with it. A shallow angle makes it easier to roll beads, especially if you want square sided beads. Steeper angles force you to move the handle a lot more when turning a bead and it's hard to do it consistently. A shallow angle gouge will let you turn the bead with less handle movement. The same is true for coves.
GaryG in MD
>Thanks John, that's good info. You're certainly right about the "practice" part. ...Gary
