Rubberized CA glue
Rubberized CA glue
Rubberized CA glue
Bill Howatt
>I read on a recent post about Rubberized CA glue. A Google search revealed from a vendor that is supposed to be better for gap filling and vibration. I assume the bond is not as brittle as regular CA.
I had never heard of it before. Any comments on the usefulness of this product?
Thanks,
Bill
Re: Rubberized CA glue
Barbara Gill, Remlik VA
>I have used the flexible CA from Starbond. Thanks to Carole Valentine I use it to attach collars to hollowforms.
JohnKyler
>I have been using the flexible from Rockler on pens and have had much better success on tube adhesion. Also works on materials that are flexible, that would not normally work with brittle CA.
John
I tried it...didn't like it
keith zimmerman, Normal, IL
>But, I probably tried to use it in the wrong application. I wanted fill a gap, which it did, but without any flexibility.
I haven't tried it since.
keithz
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>I use a lot of it. I put together sculptural pieces -- using it in places I would never think of using regular CA glue because of its brittleness. I have even found it byu far the best glue to put new velcro on my sanding pads -- and if it stands up t that, it is pretty flexible and tough stuff! It is available f rom Starbond in the US and from Lionel Bedard (http://www.belgreenwood.com/) in Canada.
Bruce McElhaney, Spring Lake, Michigan
>I use E-Z Bond rubberized CA glue on my bottle stopper mechanisms. It works great and is a breeze to use, just two or three drops on the threads. I use it for a bit of extra insurance against movement when stoppers are exposed to changing refrigerator and room temps.
Thanks - it looks like I"m behind the times!
Bill Howatt
steve worcester
>I use the Stikfast flexible for glueing the wood to the waste block. Gives me some better security when hollowing in case there is a catch of something. Doesn't shatter like regular CA.
