Wild Hare: Tight Rope Walker #1 Done
charlie belden
>Did a nicer base - with 6 coats of garnet shellac - leveled and followed by 5 or 6 spray on coats of lacquer. Turned new upright supports (candle stick holder type things) and dyed them with Behlams. Also turned another finial/flame for one of the "candles", turned african blackwood pegs - one for the right "tight rope" collar and another as a bottom stop for the left "tight rope" collar. Both pegs can be removed to allow the "candles" to be removed from their "candle in order to remove the ornament. Also now hold the "tight rope" in the moveable "collar" with a couple of knots - so the "tight rope" can be replaced if need be.
Since, if anything goes wrong for this piece's owner, I'm probably going to be the person who fixes it, I want to make repair and replacement of parts as easy as I can, and still have the piece hold together in use.
I either need to get a much larger seamless background, or not making any more pieces this large. And even though I used two 500 watt photo floods - with bounce light umbrellas, I still got two "eyes" on the ornament body. May have to add a 3rd photo flood, with bounce light and spend some time arranging them in order to get rid of the hot spots.
It seems that being able to turn interesting things is no longer enough. Now you also need to be a decent to good photographers as well - sigh.
And with pieces that have actual movement, a video is also required - which means having to become a decent videographer too. Then, the video needs a sound track - so add audio engineer and musician / composer to the mix of needed skills. So I'm getting better at I Movie and Garage Band. Now I just have to figure out how to synch the sound track to the video. SIGH!
If holograms become required I'm hangin' up the lathe!
Comments, suggestions and constructive criticism welcomed.
Re: Wild Hare: Tight Rope Walker #1 Done
>Charlie, I would love to see a video. That's a pretty cool piece. When you have reflection problems the solution is usually not more lights. That just adds another reflection. The trick is to use one light. Move that light around until you get the right look as far as shaping (which are the shadows) and the least obnoxious place for the highlight (which is the reflection of the light source). Then for the fill light, it needs to be as large as possible. Quite often bouncing off of the white ceiling might be enough. You may have to dim your main light by putting wire screen in front of it or moving it further away. You could also add 2 lights close to each other to bounce off the ceiling to bring the fill light level up if necessary.
In my Studio I often use translucent panels that are 42"x80" for the fill light. Sometimes you don't actually need a fill light. Just put a large reflective white panel just barely outside the image area. This will often bounce enough of the main light back into the frame to fill in the shadows.
charlie belden
>john:
thanks for all the certainly valuable suggestions.
What I NEED is the patience to take the time to Do It Right - which probably is to wait 'til daylight and use reflectors and diffusers, along with an adequately sized seamless background - in an appropriate color. But when I finally get a piece I really like done, it's usually midnight and I have to clear off the top of a bench to get a place to put the piece to photograph it. Making space for even my PVC pipe and plastic pebbled light diffusers Light Box just seems to take TOO LONG. In this case, even if I had set up the light box, this piece wouldn't fit in it.
This piece, unlike typical turnings, takes up a lot of space, relatively speaking, 5"d x 21"h x 23"w. Fortunately, it's not very deep, so depth of field isn't a problem. The mirror finish on the base will, if viewed from the right angle, "mirror" the "candles" and suspended ornament, adding additional visual interest if the piece is sited well - like on an entry hall or foyer (sp?). Makes for some tricky photography to see that - but . . .
The piece is meant to be interacted with - sliding the left "candle's" "collar" up and down the left candle to get it to "walk the tight rope". If you twist the left "collar", you can get the "rope" - and the ornament - to swing - like a jump rope. If you poke the ornament body or the "icicle" it will rock - left/right, fore/aft, setting the birdshot inside the ornament in motion, creating a rain stick type of sound. Get the ornament really swinging, and the internal counter balance of the "pendulum" finial will tap the inside sides of the ornament, making a tapping sound sort of like a metronome.
This piece almost moves by itself. A small gust of air, or someone walking by it quckly, will set it in motion, albeit small but perceptible movement. And if you play with this thing you can generate all sorts of interesting motion and combination of motions.
Once I figure out a way of allowing the "sliding collar" to move easily and without marring the "candle" it rides on - yet still be able to position it and have it stay there - the ornament can be positioned anywhere between the two "candles" - appearing suspended in air since the monofilament line isn't very noticable.
Though some of the components of this piece could be improved - better shapes and proportions - and the finish, with the exception of the shallac and lacquered base - could be improved, I'm really pleased with how this idea came out. I intend to do others - but - as the old saying goes "The road to hell is paved with good intentions". I lack patience and am easily distracted - so - to be honest, there probably won't be a Tight Rope Walker Ornament #2.
I'm going to have to enlist the help of one of my "adopted" neighborhood kids when I do a better video of this piece since - with lights and tripods I can't operate the camera AND make the piece move in its different "modes". Would be nice if I could include the sounds this piece makes when it moves - but . . .
Fun this turning thing!
GolfSteve in Calgary
>Visually it is very interesting and I'm sure if I was walking by it, I would be drawn to it like a magnet.
I've also loved your explorations with other moving pieces.
Cheers,
Steven
Frank Joseph
>That is really nice. I wish I could Make the same, No dream up the thing than make it. You really made a very nice thing a bob. I envy your ability
Ace Foster
>Didn't they tell you the job was dangerous when you took it?
Re: Wild Hare: Tight Rope Walker #1 Done *LINK*
charlie belden
>Frank:
There's really nothing magic about being "creative". It is something anyone can learn to do, or rather unlearn how NOT to do. And there are all sorts of ways of coming up with "creative" ideas. And none of the parts of this piece are beyond most turners, including you. Like many "problems" which may seem overwhelming, if you break it down into smaller pieces you find that each of the small pieces are within your capabilities to do, or can be.
This piece didn't just spring into my head - whole - with all the Details and How To worked out in advance. And the first attempt at the body of the ornament didn't work - so I did another one.
I didn't think of using a stud earing "friction clasp" thing - that was suggested by a guy at a jewelry supply store.
Putting lead birdshot inside the body of the ornament wasn't thought of 'til late in the project - a result of working on a Rain Stick.
I had no idea how far apart, or how close the uprights should be for this thing to work in a pleasing way. That was a Trial & Error thing.
Though I knew I wanted to use two "collars" on the upright "candles" - one fixed and one moveable, I didn't know how I'd do that, or where the fixed collar should be placed. Again - Trial & Error. I did leave options open for Trials - and Errors - so I could recover if an attempt didn't work out (note the avoidance of the word FAILURE).
I knew I wanted to use monofilament line for the "rope", but had no idea how it would connect to the "collars".
Hell, I had no idea how tall the "candles" needed to be - until I'd finished the ornament. And I didn't know how big the ornament would be 'til I turned the parts, dry fit them together and hung the assembled ornament on the "rope".
I hadn't planned on turning a lead fishing weight to stick on the bottom of the ornament's "icicle" in order to get the balance right, nor did I know I'd need a black onyx ball to cover up the bottom of the hole through the turned fishing weight.
I started with a very basic idea - that we've all seen in a kid's toy, or at a circus - and things developed as the parts and pieces were done. Somje of the initial parts didn't work or didn't look right - so I did a few more.
What I'm trying to get acrossed is that YOU - and anyone else who wants to - CAN come up with interesting ideas for a piece AND figure out a way to make it - and make it.
My seventh grade teacher, a very sweet Austrian Franciscan nun, drummed into me that CAN'T Means You Don't WANT To. With very few exceptions, she was absolutely right. If you TRY, you'll more often than not, find that you CAN. If the first attempt doesn't turn out quite like you expected - figure out why - and try again. And while shooting for perfection is admirable, cut yourself some slack. Close Enough - for you - may be seen as perfection by someone else. Don't be over critical of your turnings - but do keep working on improving.
I've posted this url before - but have a look at the stuff anyway. Might trigger YOUR next Wild Hare Project. The Wild Hare Ideas Tent has plenty of room for anyone who wants to step inside - or more accurately - step outside - "the box".
Brainstorming
Re: Wild Hare: Tight Rope Walker #1 Video *LINK*
charlie belden
>Have put up a YouTube video of this piece in action. The earlier video of it earlier on as it was being made was a Quick & Dirty. This one's of the finished piece - with better light - and I knew what I wanted so it's one continuous clip.
Note the behavior of the finial as the piece rocks.
Still need a larger seamless backdrop - but the vid does show the various modes of motion of this piece - rock left/right, rock fore/aft, move front/back and slide left/right.
Doesn't have the swishing sounds the birdshot inside the ornament body makes as the ornament rocks and slides, nor the tapping sound the pendulum finials counter balance makes as it strikes the inside of the ornamanet when the piece rocks far enough.
I need to add peg to the moveable collar - attached to it with Tiger Tail to the moveable collar so it isn't lost - and drill a hole for it through the moveable collar - and the "candle" - at the point where the ornament will be centered between the "candles".
I'm going to do an illustrated Instruction Manual for this piece so the owner knows how it can be operated - and the inside of the ornament body accessed to change its content if desired. (Great place to store loose diamonds since no one would think of looking inside the ornament.)
Finished Tight Rope Walker Video
