>There I was just having fun hollowing out a nice size Hackberry hollow form when all of a sudden there was a loud bang. I thought I blew the piece up but then heard a loud sound like air escaping from somewhere. My air hose that I have an attachment on to stick in the hollow form to blow out the chips and lay on the bed ways when not using blew a big split in it. After going inside the house to change, i decided to call it a day. So where might one get a good air hose?
You might look into getting a polyurethane air hose. Most are service rated at about 200 psi (above the high-pressure bleeder valve on most 'standard' air compressors, usually 125 or 175 psi), so 'aneurysms' and blow-outs are not likely. These hoses are typically smaller in diameter than rubber-based hoses, are more flexible, and remain so even in cold weather. I have been happy with transparent blue- (or other) colored polyurethane hoses called "Flexeel" (I now have three of them), which are available in 25, 50 and 100 foot lengths (maybe longer??); they also sell a self coiling hose (25 ft max) which is the one I use at my lathe; this has been in service for at least 4 years without a concern.
Sorry to hear about your cra% - I hope it can be replaced... ;^)
>Yeah, it took a minute to figure out if I'd been shot, the form blew up or what. I was lucky it didn't whip to far and got stuck on the banjo handle. Hose has been replaced and now I'm looking for some lead shot to fill my D handle to help dampen some vibration in the deeper hollow forms.
>Stanley Bostitch makes a contractors series air hose rated at 300psi, they are good, I have 3 50' hoses and never a problem. You have to make sure of the correct hose connection to your tools. DonL
>Had a similar incident happen to a friend that I used to work with. He was sitting on a motorcycle on his lift when the air hose hanging from the ceiling busted loose and started whipping around his head.
It broke out both the florescent bulbs that were in the fixture over top of his head. I think he had to change his shorts after.
The rest of us were rolling around in the floor watching him trying to dodge flying hose and flying glass.
>Actually that could have ended in disaster. If close enough to your skin and if the pressure was high enough it can pass air bubbles into your bloodstream through your skin. Too close to your ears and loud enough and you'll have hearing damage. Glad your okay.
>If I had it to do over again I'd go with "Goodyear" rubber hoses. The poly hoses "hold" their shape. They curl around you legs and anything else they cam (and will) wrap themselves around. Make for a nice tripping hazard and they wrap around anything they can. Glad to hear your OK!
Scott, when he has to change his shorts, go for the boxer briefs...
