Round boxes, help!
Mike Nelson
>I need to make two 1 1/4" round boxes to go inside boxes with finials. We want to put birth stone necklaces in the small 'balls as a graduation present. What would be the simplest way to turn the box spheres? Mike
Round boxes, help!
Mike Nelson
Re: Round boxes, help!
>Do a google search on Turning wooden balls. There are some really good tutorials. I use a homemade cup chuck in the headstock and tailstock to finish the balls.
For boxes you kind of need a pattern unless you've turned a bunch of them. This helps you keep the inside smaller than the outside.
I hollow the inside and make the box lips. Then I put the box together and following my pattern turn the ball shape close to size but leave a little large.
Then I put the ball in the cup chucks. When you turn it on you will see a ball with a shadow around it. The shadow is the out of round areas. Gently turn these away. Then rotate the ball 90 degree and do it again. Rotate it 90 degrees perpendicular to the last cut and do it again. After a few rotations you will get it pretty round.
Do a few test balls first. Your first ones will get quite a bit smaller than you wanted. I find a skew laying on it's side is an excellent tool for fine tuning the shape of the ball.
Mike Nelson
>Thanks John, I made one but the problem is if you crank down too hard you crack it, too loose, burn marks. Do you use anything to hold the two halves together or just a tight fit?
