Ice cream scoop adhesive question
Ed Moore in SW VA
>Due to the temperature extremes that a brass ice cream scoop might encounter, I am wondering what might be the best adhesive to secure the handle. The ice cream is cold of course, but we might rinse the scoop in hot water to help scoop really cold ice cream or to simply clean it off. For this reason I don't think that CA glue would be optimal.
Possible choices:
A. Epoxy
B. PC-7
C. JB Weld
What would your choice be, and why?
TIA,
Ed Moore
Re: Ice cream scoop adhesive question
Bruce McElhaney, Spring Lake, Michigan
>Ed, I use rubberized CA glue for bottle stoppers mechanisms which go through similar extremes in temp. Never had, or heard, of a problem with any of them. OTOH, I'd probably just use what I had on hand. But what's the worst case scenario? If it came loose, just re-glue it with a different adhesive.
Greg Haugen
>Ed,
I have one of the prototypes, before they were available through the stores, from Alan Lacer in our kitchen. It's been used a lot and for quite awhile. I used a two part epoxy for the adhesive and made a cherry handle on ours and haven't had any issues except for everyone who uses it or sees it threatens that it will disappear when they leave. :-))
>Ed I've been using 2 part epoxy for many years for all sorts of things. The temperature extremes your talking about won't even phase it. Possibly if you put it in the dishwasher it might but then the wood would be damaged.
Mike Stafford
Silicone adhesive....
Mike Stafford
>I frequently use silicone adhesives for application of metal or glass affixed to wood. It will not come loose, is unaffected by temperature extremes and will compress and expand a little with the metal. I have never had anything come loose using silicone. A little dab'll do ya'.....
Jennifer@Indy.USA
>In Alen Lacer's classes we always use 30 or 60 minute epoxy when we make the ice cream scoops. I've made several for friends and family using this and have never heard of one coming loose. I would avoid the CA glue due to it being brittle in nature.
Jen :)
