OT: Epoxy or Gorilla Glue
Cyril Griesbach
>I've got to extend a 4x4 deck post with cedar to pressure treated. My plan is to use four 3/8"x4" dowels about 3/4" in from the corners. I'm limited by access to only one side of the lower treated 4x4 and plan to also use a steel plate on that side. The post will be covered with a composite sleeve. Would Epoxy or Gorilla glue be best for gluing in the dowels or doesn't it matter?
Re: OT: Epoxy or Gorilla Glue
Bruce McElhaney, Spring Lake, Michigan
>Do you plan to turn it?
Bill Howatt
>If the dowels fit tightly in the holes either will work. Since the joint will be essentially weatherproof either will work. The reason I say these 2 things is that I made 2 3' diameter wagon wheels with spokes. One wheel was done with epoxy and the other with polyurethane glue. Where the spokes did not make a tight fit in the hole in the rim, the epoxy was an obvious winner after a few years. Polyurethane glue is not a gap filler.
Bill
>I have used Gorilla Glue. I prefer using epoxy for outdoor purposes though.
Russ Faifield
>I would use epoxy because it doesn't require clamping, fills gaps better, and has a stronger bond. Gorilla requires clamping, otherwise the expanding glue will pull the joint apart and the foam is a weak joint.
>Personally I haven't found anything gorilla glue will do that either epoxy or wood glue won't do at least equally well if not better and they are much easier to clean up. Epoxy will fill gaps where gorilla glue won't. You can change the cure time of epoxy for longer assembly times.
I probably don't understand...
Thad
>...and am open for the education.
I may not be understanding the application properly, but I would probably consider using an appropriately sized hanger bolt myself.
~ Thad
I would use epoxy if it were me
keith zimmerman, Normal IL
Cyril Griesbach
>Thanks to all. Epoxy is what I used and when it's cured I'll be adding two steel plates as well.
