Measuring Hollowform Thickness *LINK*
DC Powers
>Has anyone used the Kelton calipers? The claim is that they measure
both bottom and sidewall thickness with minimal tangential error.
In my limited experience with hollow forms, I've used the standard double-ended caliper as well as the Veritas thickness calipers, but don't own either.
Any other ideas or favorites?
Kelton calipers
Re: Measuring Hollowform Thickness *LINK*
Scott in SoCal
>I'm currently drooling over the Thompkins Gage't.
http://toolmonger.com/2008/05/29/its-just-cool-tompkins-gaget-bowl-gauge/
I think it does similar things as the Kelton design, though the Kelton might be able to handle some vessels more easily, I've never used it so I'm not exactly sure how it works.
Re: Measuring Hollowform Thickness------WebKitForm
Charles Watson------WebKitFormBoundary+ATeQdvhmFc4
>Measuring hollow forms can be tricky, especially depending on the size and shape of the turning. Some commercially made calipers are more suited to open bowls, and some that can be used on hollow forms are difficult to read the scale to see the wall thickness. Probably the most versatile is the homemade caliper which David Ellsworth uses.
Of the commercially made calipers, I use the Veritas, and the figure 8 calipers more than any others (believe I have or have owned all of them).
------WebKitFormBoundaryZ3grtNHk+Z9BL+AV
Steven Antonucci
Bent armature wire
steve antonucci
>By far, the most versatile measuring tool on the planet is a piece of bent wire. Simply bend a piece of 3/16" armature wire into a "loop" with the two ends pointing at each other.
Set the gap to a size (let's say 1") and use the inside leg to feel the wall of the vessel. The outside leg will be visible (let's say 3/4") The difference (1/4") is your wall thickness.
As you get better, you can shrink the gaps and the holes you turn through, and still use the caliper...
Steve
