Microwaving a large bowl
Mike Brazeau
>A friend wants a fairly large salad bowl for a wedding gift by Mid-Sept. I roughed a 15 1/2" cherry bowl on Saturday to just under 1 1/4" wall thickness. Anyone tried microwaving something this large and had a positive experience? It just fits in a 30 year old Toshiba uwave that we have and is unofficially designated for turnings. She doesn't mind a bit of an oval shape. This wood was from a standing dead tree, so it is not sopping wet like fresh wood. Peripheral wood is about 25% and core was damp.
Re: Microwaving a large bowl
robo hippy
>If she doesn't mind a warped bowl, turn it down to about 1/2 to 3/8 inch thick, wrap a couple of layers of newspaper on the outside, put some of the plastic shrink wrap, (the stuff that goes around boxes to keep them on a pallet)around the rim, 6 inch wrap, about 1 1/2 inches inside the bowl, the rest on the outside, and cut out the paper on the inside of the bowl. It will be dry in about 2 weeks. A work of caution, I have found standing dead trees tend to crack more than standing green ones. This method does work very well for me, even on Pacific Madrone which is the most difficult wood to dry I have found.
robo hippy
>I just turned 4 bowls 16" down to about 12" from box elder and did what Robo suggested. They all dried perfectly in about a week and a half. I turned them down to 1/2".
Ralph
>Mike
Robo's method works, but so does using the uWave. I've used both and can't tell you which method I prefer
Mike Brazeau
>Thanks all. I am trying the microwave route this time using defrost cycles for 15 minutes, at least in the early stage. Bowl doesn't get terribly hot, but I will decrease time somewhat perhaps as moisture drops. Have done some smaller things before but never anything this large. Am finding the 30 year old unit doesn't have the power it used to, so will take a bit longer probably. Just have to remember to go downstairs and start cycles. Taking note of the other method and will try when situation is not critical.
