How do I cut an HSS cutter in half?
keith zimmerman, Normal, IL
>It's too long to fit into a hollow vessel without making to opening much too large.
Thanks in advance.
keithz
Thanks in advance.
keithz
Re: How do I cut an HSS cutter in half?
Dennis Yoder
>Keith, I use a grinder with a metal cutting disc to either cut thru or score the cutter and then break it in a vice. Dennis Y
D. Hansen
>I'm assuming the piece you want to "cut" is square. I angle it about 45 degrees to the edge of my grinding wheel and score it.when it is about half way through I simply snap it. You can also just grind it through and you will have two pieces with the tip already beveled.
Lan Brady
>Keith,
I use a 1" cutting disk in the dremel.
The smaller bits can be cut all the way through.
1/4" bits, I score on all 4 sides and snap with 2 vise grips.
Lan
>All of the above and you can also just score 1 or 2 sides with a triangular file and then break it. The more sides you score and the deeper you cut the cleaner the break. I have sharp edges on one of my grindstones so I just touch a few corners, put it in a vise and break it. Put a cloth over it so it won't fly because it will really shoot out of there.
Harbor Freight 1" Diamond Disk, abt $5
Al Kapocius
Other hollow idea
Ralph
>There is also the trick way to do do really narrow hollow forms
Drill a small hole, too small to reach into. After you have parted the base off, hollowed from the bottom, then glued the base back into the hole
