want to buy a spindle gauge for a parting tool
Wayne Carson
>Have been looking for a spindle gauge for a parting tool. Have looked at the one made by Sorby but would like the older kind with only one set screw. Does anyone know of a source for the kind I am looking for?
Re: want to buy a spindle gauge for a parting tool
Steven Antonucci
Does not compute?
steve antonucci
>I read it three times and I'm still not sure what you are asking for? Can you re-ask the question a different way?
Steve
Re: Does not compute?
Bill Howatt
>I think he wants the gizmo that fastens to a parting tool to set the depth of cut. It would have a setscrew(s) on the portion that fits on the cutting tool shaft to allow adjustment in and out thus varying the depth of cut.
Bill
GalenV in Iowa
>Wayne
I have seen Sorby show two versions. One with two thumb screws and the other with two larger wing knobs. I assume they need the two to lock it tight since it is to be able to mount on diamond, flat and bedan shapes. One screw would tend to allow it to rock and not hold a good setting. You could probably make one to fit your specific parting tool and get by with one thumb screw.
I thought I saw one on a web site but have not been able to trace back to it. Surely someone has made a copy, unless Sorby's is the copy.
Galen
Greg Burnard
>This is an easy one. Sorby Sizing Tool. Available from Craft Supply USA for $32.99 , page 17 in the Spring/Summer. It clamps on a parting tool, for sizing spindle work. They call it "new", I've had one (Sorby) for 40 years. Enjoy!
Steven Antonucci
Now I get it...
steve antonucci
>I read it as spindle gouge, not gauge... d'oh!
check out Peter Galbert's spindle sizing caliper. It's a pretty neat device and works for any size with no tools or adjustments.
S
Steven Antonucci
Re: want to buy a spindle gauge for a parting tool  *LINK*
steve antonucci
Galbert Caliper
ebd
ebd
>I tried one a few years back. I didn't find it precise enough for what I wanted to do. It could have been my technique.
Re: Have you ever used one of these things?
Russ Fairfield
>Have you used one of them and know their limitations??
My opionion is they are one of those things that look like a useful tool, but are totally useless in real life. I don't know of anybody who uses one of them. Others might.
It can only be used when you are very close to the desired diameter. The gauge is in the way for tuning down to that point. That means having to remove it if there is a large diameter difference, and attaching it when you get close. You will have to use a spring caliper for that, so you may as well use the caliper for the final dimension and forget the gauge.
The other thing is that the parting too is forced into a straight-in plunge cut, and I would rather be riding on the bevel to avoid tear-out in the wood.
Buy a spring caliper, or use a box-end wrench for sizing tenons.
>I have used the sort which fit on bedan tools. I'm better served by my caliper and by my Lee Valley gauge.
