Let There Be Light - on the cheap
charlie belden
>I'm working on a Rain Stick (another Wild Hare Idea) and have to hollow out "the stick" - in 6-8" sections. Now the I.D. needed is only a bit over 2". Cutting straight inside walls 6 to 8" long - with a3/4" skew - AFTER you've turned the outside profile - is kind of trick - at least for me.
The problem is seeing where you're cutting. Much past about 4", an external light source just gets in the way.
Here's a cheap and easy way to get light where you need it - inside the piece - where the tool is cutting (actually I watch the surface opposite of where I'm cutting since at the cutting spot chips and scraping dust obscure the cutting point).
I think I found this at ACE Hardware - for about $3. It appeared that you had to keep your finger on the "button" to keep the damned thing lit - a bit of a problem for the application I had in mind. Only when I tried to remove the "clip" did I discover that when you rotate the clip over the On Button - the light stays on! Not an obvious switch arrangement - but it works.
(Now I just have to figure out how to get what looks like a not very cleverly disguised pipe bomb through airport security. I'm pretty sure the lead birdshot inside is going to show up on the X-ray machine - and I HATE being hand cuffed, let alone "harshly interrogated". I once spent 8 hours in Panama's Carcel Modelo (Model Prison - which it definitely is NOT) with the Guardia Nacional, and another 2 hours with Panamanian Immigration folks. Been there, done that - don't want another T-shirt)
