Laser that scribes an arc *LINK*
>Terry Bourk was kind enough to send this my way. It's on the Stubby site and was designed and built by Bill Rubenstein. You have to read all the literature pertaining to set up and using the boring bar system he has designed but it comes with a laser set up that once adjusted can be rotated in an arc around the radius that you set. This makes it much easier to adjust to keep the laser dot perpendicular to the side of the vessel.
The way I do it now is to put a rare earth magnet on the cutting tip. I have painted the magnet and put marks up to 3/8" in 1/16 increments. I put the magnet on the tip, rotate it to be parallel to the wall section I want to work on and then put the cutter back into the vessel and cut that area. Very accurate and simple but slow and you have to remove the tool from the vessel.
http://www.stubbylatheusa.com/cgi-bin/index.py
