A55 Smoothing Plane
What do you to finish your handles?
Jim Stoppleworth
>Oil, wax, buffing only, lacquer, unfinished?
Just finished two handles for my Thompson bowl gouges. From Doug's site the instructions for handles say oil. I usually use Minwax wipe on poly. But I'm having a debate with myself this time. Handles are cherry and walnut. What do you or would you use?
Re: What do you to finish your handles?
Charles Watson------WebKitFormBoundary+ATeQdvhmFc4
>waterlox has been my finish for most of my handles
>Depends on the handle. For hammer handles and similar hand tools, I use oil/poly mix. For turning handles, I usually use just straight oil.
I have a friend who "suspends" his handles in oil for a couple of days and then takes them out for a couple of weeks to cure. Don't know if I would go that route though.
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>I generally use an oil -- and I only sand the handles to 80 grit because I want to have some "grip" on the handle when it is dry.
>I use my tool handles for both finish testing and sometimes finishing techniques such as dyes, wax application, painting etc. I might try different finishes to see how they work and hold up. I would say most of the time I just lacquer since that's the technique I use for my hand mirrors.
Joe Herrmann
>I just finished making some handles for some of my new Thompson tools as well. I used Bush oil initially (I bought some at Saratoga Springs but usually use BLO) and then spray Deft that was rubbed out with 4/0 steel wool. I think this treatment works good and is what I use on most work, both turned and flat. However, depending on how large the work is, I might opt for brushed on poly instead.
Joe
Re: I haven't used anything....
Donna Banfield
>I've turned about a half-dozen handles, and I've never put any finish on them. I sand up to 320, and then burnish it with the chips/shavings.
So, what am I missing? And why might I want a finish on the handles?
Jim Stoppleworth
>I'm thinking along those same lines for the cherry handle. I don't think there is an ironclad reason to put finish on a working handle.
I guess since our tools that we purchase handled are almost always finished we get in that mindset for the ones we turn.
Steven Antonucci
I've been known to use my birdseye maple handles
steve antonucci
>as hammers and worse! I used to spray them with lacquer, which I still do hit and miss if I think of it.
Otherwise, my handle get human oiled over a great many years. Sanded if I had a bad day with the skew with whatever is laying around ALONG THE GRAIN ONLY with the tool off the lathe.
I've probably done 100 or so by now...
S
Nothing
Scott Hurley in N VA
>I also sand to only 80 or 100 grit, and don't put anything on the handles. Over time, the oil in your hands will give them a nice patina. I've also been known to sand off the finish on pre-finished handles - gives me better grip.
Scott
I make 1/4" round skews and ...
Ed Moore of SW VA
>handles with a 1/4" collet for sale. I used to just spray with a good lacquer, but decided I wanted a more durable finish. I just finished twenty cherry collet handles with a coat of General Seal-A-Cell and a two coats of Arm-R-Seal. I am VERY pleased with the results. I want my handles to look as good as possible.
Why a 1/4" collet handle? I take an 8" HSS round 1/4" rod and grind a skew on one end and a point tool on the other (three-face tool). I plan to make three 1/4" tools with HSS cutters CA'd into them. One will be straight, one will have a shallow swan-neck and the other a more pronounced swan-neck. The latter should be good for hollowing globe ornaments. This will complete a set consisting of one collet handle, one 5/32" Tee Allen wrench, and four 1/4" tools.
Note: 5/32" is VERY close to 4 mm. The blue Oneway Tee Allen wrench also works with the collets, and vice versa.
Ed
Maybe this picture will help explain ...
Ed Moore of SW VA
>what I was talking about. After posting the note I zipped up to the shop with the camera, grabbed a piece of plywood and what I wanted to show. The small oak pieces are simple caps for the 1/4" round skew. The skews are SHARP and the caps prevent unintended cuts. DAMHIKT The three tools with HSS inserts mentioned above aren't made yet.
Ed
Mike Brazeau
>I like nice looking handles and generally use some oil or danish oil to pop the grain and then a few applications of Myland's Quickbuild. Seem to hold up fine and look good. I also like to use the ferrules from Lee Valley. For a buck they add a nice touch. Osage is my favorite wood for handles. Love that smooth feel when you grip it.
