REAL MILK PAINT
disaster strikes
disaster strikes
disaster strikes
mfoster
>I went out to the shop to turn a little platter out of some crotch wood, turned on the lathe and just a click. No spinning, nada. What a way to ruin an otherwise great day.
I have an old Woodfast longbed with one of the first variable speed controls which was made by DJ Ulery. Unfortunately he passed away a couple years ago, so I am not sure what to do. I had my controls fritz out on me about 7 years ago, and I contacted Denver. He said just just had me send the controller to him and he fixed and had it back to me in no time.
I have done some very minor electronic work, but have to admit it is pretty arcane to me. I'm comfortable wiring up my shop and the like, but testing electronics is beyond my comfort zone. Any suggestions. I looked online and Craft Supplies seems to stock an electronic controller that may be the ticket. As a bonus, this controller has a reversing switch which I don't have now, but it does not have a remote on/off switch like I have now. Craft supplies may have someone that can fix the controller, but I won't be able to talk to them till Mon.
Any ideas??
Not quite latheless in VT (I have a Jet Mini)
Mike
Re: disaster strikes
Doc Green
>Mike, look for simple things first. Got power to the system?
Fuse? Circuit breaker?
Test the switch. Do you have a voltmeter? If so, measure the voltage across the switch. With the switch 'ON', there should not be any voltage, AC or DC, measured from one terminal of the switch to the other. With the switch 'OFF', you should find a voltage, maybe DC.
If you don't have a voltmeter, can you bridge across the switch? If the switch is defective, the lathe should start when you connect a wire from one switch terminal to the other.
Be careful, of course. Good luck. ~Doc
Convert to treadle lathe?
Al Kapocius
