Motor pulley question *LINK*
Scott Burr in Ben Lomond CA
>Hi All,
I normally hang out on the hand tool side. I was given a Tomlee lathe and I'm trying to get it up and running. I've never done any turning so I'm a complete virgin when it comes to lathes.
I have 1/3 HP, 1750 RPM, as recommended in the link.
The headstock has a 4 way pulley with diameters of 1, 1-5/8, 2-3/8 and 3 inches.
What diameter pulley do I put on the motor to achieve the final speeds listed on the link?
Also are the final speeds listed recommend for turning?
As said I'm a complete nubie, so any help would be great.
Thanks!
Tomlee lathe
Re: Motor pulley question *LINK*
Steve Kubien
We'll keep your secret Scott
Steve Kubien
>Scott, if you opt to go ahead with this electrically-powered intrusion in your shop, we will keep it on the hush-hush. No need for the neanders to know about it.
Now, if you want to let them in on your dark secret, you could always take the motor off and making a treadle or pole lathe. Good chances you've got better bearings thean most for such a thing.
As for your specific question, sorry, I am no help. I just plug 'em in and spin 'em round. I don't know what makes them work. (Stolen and adapted from the character Oddball in Kelly's Heroes...the funniest movie ever made.).
Good luck
Steve Kubien
Bill Howatt
>The spindle speed is related to the motor speed by the ratio of the pulley diameters.
For the headstock pulley of 1" which would be used for the fastest speed the motor pulley diameter, D1, would be a simple ratio:
D1/1=2275/1750 = 1.3" diameter.
This makes sense. If you turn the motor pulley 1 rotation the belt would turn the spindle 1.3 rotations which means faster than the motor speed.
For 1345RPM spindle speed:
D2/1.625=1345/1750 = 1.625x1345/1750 = 1.25"D
For 765 RPM
D3/2.375=765/1750 = 2.375x765/1750 = 1.04"D
For 400 RPM
D4/3=400/1750 = 3x765/1750 = 1.3
It appears that the speeds have been selected to use a single pulley size for the motor. The 765 RPM case will result in a speed closer to 920RPM though if the 1.25 dia pulley is used The speeds are typical and would work for most spindles and small bowls.
Bill
Barry Turner
>Believe it or not, I had one of the lathes about 30 years ago. The particular model that I had was slighly different. The bed ways were angle iron, but the headstock, tailstock and banjo look the same. It was a bit lightweight for my liking, but it was serviceable.
Mike Brazeau
>Boy, that lathe in many ways resembles an old Delta Rockwell Homecraft manufactured in Milwaukee in the 50's that I still have. Bought it in '69 or '70 and can't seem to part with it. Even the motor size is the same. On the Homecraft, the motor pulley is the same as the pulley on the lathe except reversed. The smallest motor position drives the largest headstock position etc. Gives a four speed range from about 600 RPM at slowest to 3800 RPM at the fastest.
bernie feinerman
>What model TomLee do you have?
http://www.owwm.com/pubs/861/738.pdf is a link to a Tomlee catalog on the www.owwm.org site. It includes a description of the Model 15 gap bed lathe. There are 2 pages that contain useful info for a beginning woodturner.
I have a TomLee #15 that I am getting in running condition.
Penn State Industries has accessories that fit - 3/4"x16 threaded parts for the headstock and MT1 for both the headstock and tailstock.
Barry Turner
>The 3/4" X 16 threaded spindle will accept older Craftsman accessories. The Craftsman mono-tube and older lathes used this size spindle with a #1 Morse taper.
Doc Green
>Scott, my first thought is to use as small a pulley on the motor shaft as you can get to fit. This will give the slowest possible speeds.
For example, if you use a 1" pulley, the slowest speed would be 583 RPM, which is 1/3 of 1750.
As speeds go, anything above 1500 RPM is tending to be rather fast and should be used for items that have been trued up and smaller than about 4" in diameter.
A popular mini lathe has a slowest speed around 500 RPM, and this is considered "too fast" for roughing out a blank for a bowl that may be out of balance initially.
Another item to consider is the tension placed on the belt. Make it adjustable by mounting the motor on a pivoting seat. Use as little tension as you can get to work at first because if you get a catch, you want the belt to slip.
It would not be a bad idea to install a speed-reducing jack shaft between the motor and the lathe to reduce the RPM to one-half or one-third of what you will get with the smallest pulley you can fit on the motor.
Experienced turners hold differing opinions about the RPM that should be used. Some like to turn fast because you can get a better finish at higher RPMs. However, working at higher RPMs is more dangerous, and the danger is real.
Keep us posted as you get closer to putting the lathe in operation. The folks here can make good suggestions to guide you along.
Good Luck! ~Doc
David Belser
>Mike glad you mentioned this. I also have a very similar Delta Milwaukee. It also has a step pulley on the head stock, the same pulley on the motor but reversed large -> small, and calls for a 1725 RPM motor.
In my (limited) experience, any time a step pulley is used, it is driven from another step pulley with the opposite orientation. If you use a single pulley on the motor, isn't the belt going to have alignment problems? I suppose you could set up some way of shifting the motor and it's pulley to keep it inline or use a really long belt or something. Wouldn't it just be easier to use another step pulley?
I'm surprised that no one else mentioned this. I'm not a mechanic, but I think you would want to keep the belt square to the pulley.
- Dave
"Make it adjustable..."
Al Kapocius
>This is an old pre-WWII gimmick. I've got a '50s Delta Rockwell lathe that I gimmicked up to "lift" the motor to slack off belt tension when turning off balanced workpieces or when just plain scared.
Al Kapocius
Correction
Alex Yeilding
>On the last equation, you inserted the wrong final speed:
For 400 RPM
Using 400 as the target speed, the motor pulley for this position works out to 11/16".
Scott, lets us know when.......
Eddie Pacheco: Antioch, Ca.
>You'll need a new scroll chuck, gouge, scraper, hunter tool, Thompson tool, live center, a few more lathe tools, 2nd scroll chuck, bigger lathe, chainsaw, new truck, new shop, and....when your hand tools are first listed here on classifieds.....:-)
use a hinge
David Belser
>I mounted the motor on a hinged board so that the weight of the motor tensions the belt.
Marv
>The speed of the spindle is determined not only by the RPM of the motor to the size of the motor pulley, but the ratio between the motor pulley diameter and the spindle pulley diameter.
so to keep it simple, just use a pulley that is the same as on the spindle of the headstock.
Marv
So this is where your hiding...
>Thanks Steve. I use that line from Kelley's hero's myself, 'ceptin I use it for computers mostly.
Thanks Bernie!
>Mines a model 15 as well. I'll post a pic or two, I just need to get them off the camera. Thanks for the Tomlee link as well. I have Penn State catalog so I'll start browsing thru it.
ROTFLMAO!
>Thanks Eddie! So the turning forum is a black hole for neanders that went over to dark side.
You forgot a new grinder set to run in reverse and wolverine jig.
I'm sure there's much more I'm missing. 8^)
Thanks
Bill Howatt
All ready done.
>Once I get a pulley for the motor and some link belt, then all I'll need to do is wire up the motor, sell my house, buy everything else I need, get a divorce, and get a van down by the river.
Woodturning is compatible with the Neander way
wilbur
>Hi Scott,
It looks like you got the answer you needed, so as a fellow Neander-leaning woodworker I just wanted to address Steve's concerns that you'll lose your hand tool cred by using a lathe.
Here's how I look at it: when using a lathe, you are using hand tools. It's the rotating clamp that's hooked up to a motor. :@)
Steve Kubien
Not bad Wilbur
Steve Kubien
>That's not bad thinking Wilbur. Still, you know there are some who wouldn't buy into that. :)
Ya Scott, I've been on the spinning side since I got my first lathe, what, 4 years ago? Honestly I haven't used a flat-work tool since, except to build storage for lathe bits and bobs or something turning related. The vortex is strong and I got completely sucked in. Heck, I know where my planes are in the shop but it would take me 20 minutes to un-bury them. Don't worry, they are safely wrapped up and waxed in a toolbox.
cheers,
Steve
