OT: Water pouring down my fireplace! (again)
Steven Antonucci
steve antonucci
>We've had a problem for the past couple of years where there is an ever increasing volume of water that runs down the flue on my fireplace. Called the chimney guys and they said it's because my brickwork is no longer waterproof and the water is seeping through.
Personally, I don't believe that. Before I have someone waterproof my chimney, I am looking for other things to consider. Cap is closed. Raining pretty hard, 2-3 gallons in the buckets...
HELP!
Steve
Re: OT: Water pouring down my fireplace! (again)
Sounds like the cap
>...may be the culprit. If it is not installed or flashed correctly, it could be funneling runoff water into the flue. I don't see how you could be wicking that much water through your brickwork. It would be nigh-on impossible if you have a flue liner in there.
Steven Antonucci
I agree- $750 price tag thrown at it
steve antonucci
>I'm not likely to get on the roof to fix it (had a fatality in the community from similar activity a few years ago.)
Why is it that I never feel comfortable with "repairmen" estimates? I always feel like I'm being taken advantage of...
Steve
I might just waterproof my bricks myself...
Re: I agree- $750 price tag thrown at it
Bill Howatt
>Check into waterproofing before doing it first. I read somewhere a few years ago that clay bricks should not be waterproofed since it actually traps the moisture and makes things worse.
Anybody know for sure?
Bill
Call a chimney sweep
Curly Smith
>You need to routinely clean the chimney anyway and part of the service is inspection of the chimney. Besides, if the cap has a hole in it they should see it when they take it off. They should also be able to tell you if it's not installed correctly.
Re: Call a chimney sweep
adrien
>Steve, our problem, with a new chimney, was water coming through the wall. Turned out to be defective soldering on the copper chimney cover. (Around the cap and over the chimney rim.) Basically, as Ellis said, a flashing problem.
>I have to agree with Ellis and the others on this.
If you are not afraid to clime up there and look Check out the top of the chimney. There should be a flue liner sticking up out of it (maybe several and there should be a coping or cap. This is mortar or Cement that is rounded of on top of the chimney to cause the water to run off. The coping may need to be replaced about every ten years. the old one should be chiseled off and a new on installed. This is fairly low tech standard maintenance and any good sweep and many masons can do it. The coping should be sound and free of cracks. IF there are minor cracks, some of them are coating it with mastic to get a few more years. Locally this work is two or three hundred dollars. You can also install a cap over the flue itself. These are available for under a hundred and basically almost snap on. You buy one that fits the flue liner and there are screws that you tighten to hold it in place. You just snug them up and the compression holds the cap.
If you decide to coat the chimney to seal it try to find Hydrozo. It is a clear sealer and it breaths. I think it is nearly impossible that gallons of water would be running in through the sides of the brick. It would be more likely it soaked through and showed up as wet stains hours or days later.
Jack Riley
>I've experienced a leaking fireplace in several homes I've owned. The leaks usually fall into one of three locations: flue not covered with cap; cracked mortar on top of chimney allowing water to enter outer shell of flue; and flashing failure where chimney meets roof. All are simple to repair even the mortar crack. There is a silicon based sealant that will work for 3 years or so on the flashing or the crack. Eventually you'll want to replace the cracked mortar on top if that is the culprit. A cap is the easiest with most good ones now being stainless steel and spring loaded to ensure a four point grip inside the flue. Good luck and be careful with that ladder!
