epoxy Question
epoxy Question
epoxy Question
Chet Gelnett
>I have a lot of very small pieces of different kinds of wood that I would like to glue together in a form and then turn. Would epoxy be better or some other type of glue?
I have a scroll saw and several years ago I cut out many different items for gifts at Christmas. All the extra little wood parts I threw into a bucket. I have two 5 gallon buckets that have been sitting there for years. Never could just get rid of them.
I have seen where this is done with pen turning but was not to sure how to do it with a bowl.
Any ideas?
Thanks
Re: epoxy Question
Re: epoxy Question
>Epoxy is fine. It is strong and will fill any gaps if the surfaces aren't perfectly flat. If the surfaces are flat and you glue them long grain to long grain yellow or white glue will work fine. In fact if you are stacking layers so you have a long grain joint over an end grain joint the yellow glue will also work.
Re: epoxy Question
Re: epoxy Question
Chet Gelnett
>Thanks, another question; Can I poor it in layers and will the epoxy stick to each other?
Re: epoxy Question
Re: epoxy Question *LINK*
Bill Howatt
>I think you should read up on making segmented bowls. Here is a good one from WoodCentral's Articles by Ken Salisbury:
You can also Google "segmented bowls" for even more info since there are other techniques as well.
Bill
Ken Salisbury's Segmented Bowl Article
Re: epoxy Question
Re: epoxy Question
>According to the pamphlet I just finished reading from West Systems Epoxy company, you can pour in layers. If the epoxy has hardened but is not completely cured you can pour right over it. It forms a chemical bond with the older surface. If it has cured, which takes 24 hours or more then you have sand it lightly to provide a mechanical bond. I've done the sanding route many times and it works very well.
