>The Monster Hollowing System I ordered in Albuquerque arrived yesterday. I can't wait to get it set up for the first time and try it our. Randy custom-sized the base for my new Delta Midi, so it should fit well. It will fun learning to hollow with an articulated system. I have several blanks just waiting to be done.
>This is a slick, well engineered and well made system that opens up hollowing for those timid souls such as myself who've had a catch or two freehand hollowing and had kissed off hollow forms.
Keep your tool manipulating hand ABOVE the scissor joints and avoid a nasty pinch in the heat of hollowing.
Hopefully you included a few extra HSS cutters in each of the two sizes so you can modify or shorten a couple for small opening hollowing - especially undercutting up around the neck opening.
While the ability to pivot the cutter to angles less than 90 degrees is great for undercutting, it does put the cutting edge out away from the centerline of the tool, Would be really nice if there was a goose neck option available which keeps the cutting edge in line with the centerline of the tool.
The laser ain't foolproof - as this fool can attest. With a curved cutting edge, where on that curve do you set the laser - and be able to visualize where the rest of the cutting edge is as you swing the tool following a curve you can't see. Would be nice if the laser threw the pattern of the cutting edge, rather than just a red dot.
Have the Mini-Monster and it opened up possibilities to try that I'd previously been too paranoid to attempt. I still turn inside diameters greater than the outside diameter occassionally, but my jaw isn't clenched anymore and my neck and shoulder muscles don't seem to feel as tight while hollowing.
Like any tool, the more you use this thing the more you'll appreciate it - and the more things you'll find to try with it.
>I have had my system from Randy for just over a week and what a delight it is. I've used it with the Delta 46-460 and it works like a dream. I cannot get over how easy it is to reset the laser. I ordered an extra base for use with my DVR. This is a well engineered system!
>Charlie Your bring up a point that frustrates me about lasers. You have to set them perpendicular to the wall being cut in order to be accurate. I have cut through the bottom sloping edge of a piece because I didn't stop to reset the laser.
I usually set the laser so the dot is on the point for roughing and then for fine tuning the sides I'll set it for the proper gap and perpendicular to that side or bottom but do need to stop every so often and reset the lazer.
You can get lasers that have designs projected by them. I bought one that came with 6 of these, one was an arrow one flipped you the bird, etc. If you could find one with a circle you could set the center of the circle at the cutter tip and not have to adjust it. The downside would be that as the size of the piece decreases the circle would get bigger so then you have to readjust the laser up and down instead of trying to stay perpendicular. I guess there isn't a perfect method.
>This is my second "system". I also have a Kelton Hollowing rig that I also like a lot. I have discovered the limitations of that rig and I think the Monster will enable me to go beyond those limitations.
the biggest limitation deals with wide shoulders on hollow pieces that are wider than they are tall. I like this form, but found it difficult to get to the outer edge of the walls with the Kelton. I think I'll be able to get out there with the Monster.
>I have had my monstor hollowing rig for a couple of months and love it! John is correct about the laser - when you get close to the desired thickness it is best to reset the laser point. The entire unit is built like a tank. John, if you ever want to stop by my place and play with mine let me know.
