Wild Hare: Tight Rope Walking Ornament *LINK*
charlie belden
>Still have to turn better versions of the parts that the uprights fit into and mount the whole thing on a nicer board - but here's the Tight Rope Walking, Penduluming Finialed, Ornament.
Note - the turned metallic looking thing at the bottom of the "icicle" is a turned lead fishing weight. Needed lead to get the balance right. Lead turns really really easily.
I put some lead birdshot in the hollowed out body of the ornament and they produce a "rain stick" sound as the piece moves. When tilted far enough, the counterweight for the finial taps against the inside of the body of the ornament - also adding sound to the piece.
Next up - another Wild Hare Idea - a turned "rain stick" piece, with internal bells made from copper pipe end caps, Jew's Harp sproingers from a feeler gauge set, spring wires to divert the "rain' (birdshot and various sized ball bearings) and maybe some grooves turned on the inside of the "stick" for some chatter.
Comments, suggestions and constructive criticism appreciated.
Video of this piece in action
Re: Wild Hare: Tight Rope Walking Ornament *LINK*
Video link
Jack Savona
>Charlie, when I click on the You Tube link, it says, "This video is private".
Anyone else have this problem?
Re: Video link
GalenV in Iowa
>I get directed to the You Tube log in site and not the link Charlie has posted when I look at the properties of his link.
Sure would like to see.
Charlie's lead turning will lead to a whole new warning on lead poisioning. Since I cast my own bullets for reloading I may try a custome turned shape. Not sure how a finial shape bullet will be accepted at the range though.
Galen
Re: Video link - Fixed (I think) *LINK*
charlie belden
>In addition to learning digital video editing, I'm still learning about YouTube, and how to post videos. Apparently I didn't deselect "private" when I uploaded the video so I could view it - but nobody else could. I think that's fixed so if you click on the link to the video in my original post it should work. If not, PLEASE let me know.
I also put up another page on this thing that has some details and photos. You can back up from that page back to my starting point if you'd care to.
Have shot the third coat of lacquer on what will be the final base for the piece and still have another set of vertical support "bases" to turn.
Now I have to figure out how to get sound with the videos since the bird shot inside the ornament makes a nice swishing sound as the piece moves, and as the pendulum finial's counter balance strikes the inside of the ornament body.
I really should finish this piece before getting into the Rain Stick piece that's up next, but ideas for that piece are flying around in my head and I want to see if they'll work. Prototyping with 1 1/2" schedule 40 PVC pipe. Much q uicker and easier than turning hollow tubes to test ideas on (actually IN).
Details web page on this piece
GalenV in Iowa
>Charlie
The link worked fine now as well as seeing all the additional details you had to go through to pull this one off.
Watching the motion I had to grab a meclizine tablet to keep from getting dizzy! ;>)
It's not a new idea but maybe for a turning how about a gyroscope. With segmented turned wood frame and gimbals. The rotor could be a combination of a wood inner disc and a lead outer disc for the increased mass. May be too simple but would be attractive done in different woods.
Did you use some type of coating over the lead to maintain the shine or maybe anything would oxidize it right off.
Galen
Re: Vertigo & Gyro
charlie belden
>I think it's the penduluming finial that causes the vertigo. The brain expects it to move in a predictable way - and when it doesn't . . .
The idea of incorporating gyroscopic motion in a way other than a top sounds interesting. I've seen pieces that use small sealed bearings to allow elements to spin. But doing a turned piece that uses the gyro idea sounds too much like machinist turning - and not my cup of tea. And the other issues is spinning the gyro up to speed. How's that to be done?
When are YOU going to give your idea a try?
Got any other Wild Hare Ideas you'd care to share?
As for the lead staying shiny - I may give it a coat or two of clear lacquer, or just let it oxidize, maybe even color it black like the icicle.
Brad Vietje
Excellent All The Way, Charlie!
Brad Vietje
>That's a very cool piece. The link and video worked fine for me, but no sound, which would be even better.
Keep those zany ideas flowing -- so much fun to have, so little time...
Brad Vietje
Newbury, VT
