Multi-axis
Multi-axis
Dick Hines
Multi-axis
Dick Hines
>I want to trun a box between centers and have the top turnes multi axis. I am haveing trouble getting the rim of the top to be even all the way around. Any ideas?
It's strange what your mine does when you can only look at your lathe for over a month but can't turn anything.
Re: Multi-axis
Bob Moffett
Re: Multi-axis
Bob Moffett
>Frank Penta has some good handouts on multi-asis turning on his website, woodsprite.com. Those my help you.
Re: Multi-axis
Re: Multi-axis
Jerry Hall
>Dick,
I do a fair amount of multi axis stuff, more intuitively than analytically. But here is an attempt at an analysis for a simple design since you didn't describe your design.
You can't match a top turned on an axis that is at an angle to the box axis because the intersection of the circular box to the circular base of an angled top results in a ellipse. Except in the trivial special case where the top is a sphere. So as the attached (inaccurate) drawing attempts to illustrate you have to resolve the two circular solids on an edge that is above the top of the box. Then you can have a circular interface to the top to the box. Clear as mud? I can turn one and photograph it if you want. I think this design has possibilities!
I gave up solid geometry many years ago, so I fully expect others whose brain is still working to offer up a better explanation (and likely a more correct one.)
Re: Multi-axis
Re: Multi-axis
gtwilkins
>Frank Penta's site is frankpenta.com but it has been hacked and is down!
Trevor
