Cigar Pen Failures
Marianne
>Hello,
First - I will admit I buy pen kits that are not expensive. Normal retailers are at about $7.00 a pop. Several of my cigar pens are exhibiting the same failure signature: when you press down to write you see the top part of the pen rotate and the pen tip goes up inside of the pen. I have used these pens heavily for two years now and they have the same failure signature. Before performing a DPA does anybody know what is causing this? Has the copper insert in the top part of my pen come loose and I need to do a better glue job? Thanks for any info. Marianne (and really do not want to perform a pen autopsy as these pens are my favs)
