>Mike If I have time today I'll show you a trick to get the color back into the top of the vessel. Your getting glare from the back ground and there is a simple trick I use when shooting table tops that will work on a smaller scale for your box. I'll shoot a quick photo so you can see what I'm talking about.
>John, I would appreciate that. Jamie has also been helping me but I have not found the right combination yet to eliminate the halo and glare you are talking about.
I desperately need to learn how to take photos with my new camera.
>Mike When you are shooting with a bright white background it will often reflect in the top of the subject. In this case it takes away the color. The trick is to simply put something else outside the photo area for it to reflect.
In the series of photos below the first one is a straight shot with one light lighting the piece and one shining on the back ground. This gives an even lighting although it's kind of flat looking but for our purposes it will work. You see how there is glare on the top and on the right side. In the second photo I put a black cloth over the background just barely out of the picture area. That made the top darker. then for the photo on the right I simply took a black card and put it back to the side so the side picked up the reflection of the card and gave me some color there.
If black is too much, then use gray or simply take a card and cast a shadow on the back ground out of the picture area. To figure out where the problem is coming from think of the reflection like a pool shot. The camera is the pool cue and the top is the rail. Where the ball would hit the back ground is where the black card needs to be.
>This technique is what photographers call negative light. You are removing some of the light. It works amazing well. I use if for all sorts of thing from outdoor portraits to lighting jewelry.
Hope that helps. I've got to pack up to go shoot the Womens soccer team. I know, it's a tough job but somebody's got to do it.
>...examples, I sometimes shade bright areas like backgrounds with a piece of black screen wire, just enough to kill some of the brightness without casting a shadow. The trick is finding ways to hold it in place without having to use your hands! A light stand with "snake arm" and alligator clamps works for me, but then old photographers have a collection of studio toys to go with our bag of tricks! (;-D)
>Mike The screen works best between the light source and object, as well as anything else translucent. I use anything translucent to change the character of the light or the intensity. white paper, cloth, screen, etc. Wire screen is good because if necessary you can lay it directly on the light. Paper or cloth might catch fire.
Just about anything you do will affect the light somehow. Many times simply moving the piece left,right, forward or back in the light booth will change how the light hits the piece. For example if you use one light and in a box like Jamie's Frugal system, moving the piece closer to the light brightens that side and since the light has to travel further to bounce off the other side of the booth and get back to your piece, the light on the bounce side will be darker. This increases the shadow on one side and raises the light on the bright side. Moving the piece away from the light and closer to the bounce side lowers the contrast by reducing the bright side and raising the light on the shadow side.
Need more light on the front of the piece, just move it deeper into the booth, or add a bounce card or both.
