Jam Chuck Questions
Bob Lalonde
>What do you use to protect the inside of a finished bowl when it is jam chucked up to finish the bottom?
Jam Chuck Questions
Bob Lalonde
Rubber sink stopper
>I have 2 things I use. One is a plain old rubber sink stopper. On smaller bowls I will simply place this over the chuck and then bring the tailstock up and turn. On larger or at least deeper bowls I have a wasteblock that has a tenon on one side to fit my chuck, and a piece of industrial rubber glued to the other end. A sink stopper would well here also. the piece of wood is long enough to keep the bowl edges from hitting the headstock.
Re: My jam chucks are faced with....
Jamie Donaldson
>...materials like mouse pad or router pad foam, leather, or any variety of materials that add both traction and padding. John's sink stopper is something I haven't tried- thanks John, I'll have to go shopping in the kitchen section next time.
Re: Rubber sink stopper
Paul Zerjay
>I use a 6" pad that's made to use as the final buffing pad for corian.
Re: Jam Chuck Questions
>Mouse pads work for me also. There is also a waffle weave shelf lining material. It is fairly "grippy".
Martin Harris
>I had been using a mouse pad until a couple of weeks ago. While finishing a thin bowl (1/16" thick) it over heated or slipped and the pad got too warm and disintegrated, ruining the inside of the bowl. So I tried again with a piece of scrap and easily got the same result. The mouse pads, although only two years old, were disintegrating! One other thing to check with mouse pads is that the dye doesn't leech onto wet wood.
Cheers,
Martin
keith zimmerman, Normal IL
>If I'm turning something really small, I'll turn a tenon on the waste that fits the opening. If I'm doing an open bowl, I like to use dense carpet pad between the jaws and the wood. I also have some custom sized blocks covered with rubber that I have made for certain pieces that won't work with the carpet pad.
keithz
Russ Fairfield
>Beware of things like ScootGuard and router pads that have an open pattern. They can leave a scuffed pattern in the bottom of the bowlIf your finish isn't "aged".
Don't tell anybody...
Jim Rutten
>...but my bank has these things to open jar lids in their give away bin and every time I am in there I nab some more. They have enough friction on them to keep things from sliding.
camping pad
Steve Kubien
>I've been using a 1/2" thick foam pad that you would normally put under a sleeping bag. Stuff is pretty dense and works well.
I'll second what Russ said about the open-weave router pads. Nasty results if you finish isn't as cured as perhaps you thought (even after a week).
Steve
A cut up fuzzy bathroom carpet :)
Marc Phillips
Fit between chuck and bowl
Doc Green
>The demands placed on the padding material will be much less if you have a good fit between the jam chuck and the bowl. If the profiles match fairly closely, the contact will be spread over a large area so that "pressure points" are avoided.
An open bowl with a flat and fairly substantial rim can be jam chucked against a flat surface. This gives the largest-possible ring of contact and makes slipping less likely to occur. Lateral stability is provided by the point of the live center.
The flat surface can be a disk of MDF or plywood mounted on the chuck. There are several ways to hold it: (1) thin glue block; (2) recess for jaws to expand into; (3) chuck with center screw; or (4) mount the disk on a faceplate.
If your contact area is large, almost any padding material will work. I prefer thinner pads so the seating of the piece is a bit less spongy. ~Doc
You mean a "luton"?
Steve Kubien
>If you haven't read The Meaning Of Liff" by Douglas Adams, don't ask.
>I have used a number of things. Went to an industrial gasket supply house and bought a piece of Neoprene that is about an 1/8" thick. That may be my favorite. bought a piece about 3' square and it may be a lifetime supply.
I have used the old style cheap carpet pad. Worked well, but is thicker than the Neoprene and can introduce some "slop".
Also used "Foamies" from Wal-Mart. The worked well also.
Used the closed cell foam meant to go under "Pergo" type flooring. It was OK, but tends to "wear out" as the cells burst.
I have also use the open weave shelf liner both as a jamb chuck liner and as a sanding pad. If you leave anything laying on it a while, it leaves a waffle pattern on it. Tick me off.
As others have said, you want something that is firm and does not discolor your work. Open cell foam compresses easier and that seems to be good. The Neoprene is black but does not mark the work. The old cheap carpet pad was pink, but did not mark the work.
Re: Jam Chuck or friction chuck?
Wayne K
>If I may- I always thought a jam chuck was a ring cut into a faceplate where the rim of the bowl actually snapped into. A friction chuck is what everyone is describing here.
BTW I like foamies on my friction chucks or a piece of 1/4 or 1/2 ply with a split vinyl tube around the circumference mounted to a wooden face plate.
Re: If I may Wayne, a jam chuck and....
Jamie Donaldson
>....friction chuck are the same animal! Semantics aside, they both function by friction, and the only difference is the manner of restraining the trapped bowl.
Jim Stoppleworth
>I use an old mouse pad as a cushion for my jam chucks.
Bill Blasic
>I use a 6" Abralon sanding disk 500 or 1000 grit (whichever I pick up). The sanding surface against the piece and the foam against the chuck, this has worked very well.
Bill
