Box Elder warping
Box Elder warping
Box Elder warping
>Someone asked how much the box elder will warp from green to dry. I can now tell you. 3/8". OK that's on a bowl 15 1/2" in diameter. The narrow side is 3/8" smaller than the long side. I checked 3 bowls that are all between 13 and 16" and they are each pretty close to 3/8". That's with 1/2" walls. It might be a while before I can get them sanded and finished but I'll post some photos when done.
Re: Box Elder warping
Rob Wallace
Rob Wallace
>John:
In my experience (using Iowa wood), box elder is one of the most stable of our local woods. It does not distort appreciably during drying, and your observations seem to bear that out. It's one of those woods that has a fair amount of 'screw-up' latitude that if you don't make the wall thickness uniform, or leave too much 'meat' at the base of a bowl or vessel, there are usually no major consequences, provided a slow drying process. I rarely lose any box elder pieces after rough turning. Just watch that tear out!
Rob Wallace
