vessel end grain plucking
Lewis Dodd
>I have started a vessel that instead of hollowing out the end grain, I have end grain on both sides of the vessel. This will not cut or sand well and remains rough. I have tried Elmers glue cut 50/50 with water. Been thinking about just using super glue but do not want to discolor the wood. Any products or solutions would be appreciated.
Re: vessel end grain plucking
Doc Green
>Lewis, I have used lacquer sanding sealer cut 50/50 with lacquer thinner. Slurp it on, and then let it dry for several hours before you try making another cut.
With this method, you can take only a modest cut before you get below the level of penetration of the sanding sealer. Then, you have to apply more, and let it dry.
As I'm sure you know, tools should be as sharp as you can get them. Avoid any kind of a scraping cut.
Good Luck! ~Doc
>Sometimes CA is the best solution. Put some finish on over and around the area to keep the staining from happening. Don't forget it will run so use the finish liberally.
I have 3 things I try before that. The first is to use a tool that has a sharper angle on the cutting edge. I have a gouge ground to a 40 degree grind. If that doesn't work I try my Hunter tool which has an even sharper angle on the tip. You do have to rub the bevel on that cut, not scrape. Speed up the lathe if it feels safe and push the tool at a slower rate to allow it to cut. Wetting the wood or waxing the wood helps when doing this.
I bought some white glue and some minwax woodhardener to try these two out. Usually the thinned lacquer works. If it's really punky rather than just green, it will take several coats and a few hours to dry. On these I apply quite a few coats and wait over night.
Barry Turner
>Try shear cutting with your bowl gouge, if you haven't already. If this doesn't work, there's always the 60-grit gouge...........
Wally Dickerman
>You didn't say what kind of wood you're turning The kind of trouble you describe usually means that you are cutting against the grain and possibly with a dull tool.
Whenever possible you should cut with the grain. Much the same as planing a board against the grain...you'll get a torn wood surface.
Wally
Shouldn' t that read "Plucking end grain vessel?"
Dick Coers
