name of a turning too?????
Wayne Carson
>it is used with a parting tool and is "C" shaped and is for keeping a spindle the same dia. And where can one be purchased
Wayne Carson
Re: name of a turning too?????
Gary Ljostad
>It's called a sizing tool and is made by Sorby. Here is a link.www.woodturnerscatalog.com/store/Turning_Tools___Special_Purpose_Tools___Robert_Sorby_Sizing_Tool___sorby_sizing_tool?Args=
Gary Ljostad
>sorry about the link. you will have to cut and paste into your browser.
jake Niedling
>Sorby Sizing Tool - Most turning supply stores should carry it. I checked Craft Supplies and they have it.
>It's called a Sorby sizing tool. It fits on a 3/8" beading tool. Cost's $33.50 without the beading tool.
It's much easier to simply take an open end wrench of the right size and use a parting tool to cut until the wrench drops over. I use a dial caliper. I set it to the right size and lock it in place. Then gently touch the wood while I use the parting tool to get the right size.
If I have to do repeated sizes such as when copying spindles I use outside calipers. You can buy them really inexpensively from Grizzly. I have about 12 or more. I put masking tape on them to mark the diameter. Then I label the drawing with numbers that match the calipers so it's very easy to measure different parts of the spindle.
Dave Peebles Lyons, Ohio!
>I also use an open ended wrench. But I sharpen the top of the wrench and forgo the parting tool.
When I was making Shaker chairs I needed a quick way to get an exact size on the 5/8" tenons that most of the chair parts needed. It worked great. But I found that a standard 5/8" wrench was over sized a little bit. So I ended up using a metric wrench and filed it down to a perfect fit.
I will attempt to add a pic.
Dave
Use the wrench or a caliper.
Russ Fairfield
>Save your money. The Sorby sizing tool is one of those things that looks good, but can be totally useless in real life. It is in the way of using the parting tool until you are close to the finished diameter for it to slip over the wood. That means using either 2 parting tools or not attaching it until you are close enough to use it. Either way, you will still have to use a caliper to make that rough sizing dimension.
Besides that, pushing a parting straight into the wood doesn't always leave a smooth surface.
Re: Use the wrench or a caliper.
Rob Wallace
>I've had one of those sizing tools for over 10 years - when I first got it, I probably used it twice to see how it worked.... it likely hasn't been out of the drawer after that - I never use it! (...and I've turned dozens of balusters and replacement chair parts since then)
Russ is right - it does get in the way until just before you need to check the diameter. Save your money (or if you do spend some, get a good set of calipers) and choose another way of sizing your tenons.
One of our club members was making several sets of shaker chairs (requiring the making of many repetitive operations to size the tenons), and standardized his tenons at 5/8" - he simply sharpened one side of a 5/8" open end wrench and used that to cut very consistent tenons. This might be an inexpensive alternative to buying/using the sizing tool.
Rob Wallace
don lewonczyk
>I bought a couple of sizing tools off the classifid section a year or so ago. Made for 3/4" and 1", just stick it to your spindle and work it across to a perfect 3/4" or 1" no measuring involved. The company that made it is out of business I guess because I couldn't contact them. DonL
