sanding abrasives
sanding abrasives
sanding abrasives
Mark Paulley
>Hello all,
Just wanted to drop a note to all who use sanding paper. Just got some new gold line abrasives from VincesWoodNWonders.com and this stuff is great. It goes from 60-800 grit. It is simialr to his blue line but this has a paper backing. Its only $3.25 per 25 discs. Here is the deal you get all 12 grits for $42 and that includes shipping. He also has lowered his pricing on the blue line.
I am not affiliated with his business but I am a friend and I use and need sand paper.
Re: sanding abrasives
Ken
>I'v been hearing a lot about these disc,but how do they hold up?I have been useing the new wave disc from another supplier.I won't say who,as they have bent over backwards to work with me,replacing then an all,but I will put them on the drill pad,run the lathe at 200rpms an the drill as slow as possable and they still come loose from the backing cloth that holds them to the velcro pad.Does anybody have problems with Vinces disc doing this,or will they stay together?because I want to change,but don't want to have the sme problems with these.I know most of the new wave disc are made by the same people,then sold by different suppliers.
fernhills
Charlie Anderson
>A couple of years ago, I got an order from Vince and one of the grits came loose from the backing.
Of course, he replaced it immediately.
That's the only problem I've ever had.
Re: Charlie- I've been using Vince's ....
Jamie Donaldson
>... blue plastic backed discs for about 2 yrs. now and never had one separate. I bought a similar looking blue product from another source and they have been flying around the shop all week as they came apart!I made the mistake years ago of stockpiling sanding discs of all colors and grits when I found "deals" and now many fail from old age as the adhesive has broken down. So I believe the best policy is to buy the best and save the wasted time spent trying to sand with inferior materials.
Well put Carl ;)
Marc Phillips
cliff
>just got a order of pads from vince fast service and it has worked well so far and the price was fair too.
Ken
>Thats the problem I have had with the ones I got,I was getting the gold color,but then tried the green ones(more expensive)an they wern't any better,like said I called em an they replaced them all,an they come apart.So I have a ton of em now.Guess I'll just use em up an then try vinces.
>Ken I had that happen with some 600 grit from KLingspor. I never had a problem with them before or since. I suppose every manufacturer can have an error from time to time. I haven't had any problems at all with Vince's blue discs but I haven't used nearly the number of his discs as I have Klingspor's over the years.
Charlie Anderson
>Vince's replacements did not separate!
